Shock replacement for Evil Following?- Mtbr.com
Results 1 to 29 of 29
    Mar 2013
    I sent my shock in for service and Dirt Labs is telling me there is major scoring inside the shock and it's basically shot and the cost of air can and damper sleeve (?) cost basically what a new shock costs. Assuming this shock is dead (1300 miles with no service, some sandy riding in winter), should I replace it with another Monarch RT3 or a Fox DPS?
    Mar 2013
    Pics:
    Reputation: Rngspnr's Avatar
    Feb 2016
    This;
    My buddy spoke to Craig at Avalanche and he said that Following shocks are one of the most common shocks he works on due to the leverage ratio on these bikes. He also said that it is absolutely critical to due the scheduled maintenance every 50hrs or less if you're a heavier rider. He also mentioned that these shocks over heat very quickly due to leverage curve of frame. He said he has seen many of these shocks damaged severely due to overheating.
    This too;
    https://www.ebay.com/itm/NEW-2017-FO...53.m1438.l2649
    2016 Evil Following V1
    2016 Dartmoor Primal+
    Feb 2016
    I saw in another post that someone recommended a McLeod. The McLeod is a fantastic shock I had one on my RIP9 unfortunately they don't make the McLeod in a size to fit a Following. The Following is very limited in shock selection. I would consider getting the Fox and then sending your Monarch to someone for a rebuild and custom tune. That way you always have a backup shock.
    Feb 2016
    Sorry didn't realize you were the one on the shock pressure thread.
    Reputation: Dude!'s Avatar
    I had a horrible experience with Dirt Labs. They screwed up my fork, sent it back to them, got it again, was even worse, and eventually had to send it back to the manufacture to fix their mistakes. They were difficult to deal with. It cost me time, money, messed up a bike trip, etc. I wouldn't trust a word they said!
    Mar 2013
    Quote Originally Posted by Dude! View Post
    They seem to get really good reviews and have been quick to respond and helpful with me so far
    Quote Originally Posted by Alias530 View Post
    That's great!!! Good to hear things have changed! I am not one to mention negative stuff about bikes, etc. However, my experience with Dirt Labs, in all of my years, was horrible. I hope for the best and glad to hear they are helping you out!!! It does seem that the Monarch is shock with issues. My buddy had a lot of issues and eventually purchased an 11-6 and never looked back. His experience, along with other friends with Insurgents is the reason why I am getting the 11-6 for my Calling.
    Nov 2006
    I switched out my Monarch and went to a Fox DPS when my Monarch was out for service. The Fox DPS was from Fanatik with their Evil tune. It was quite a dramatic improvement. My Following seems to ride higher in the travel but yet is more responsive in all conditions. I never put the Monarch back on the bike.
    Mar 2013
    Quote Originally Posted by Berm View Post
    I went through Dirt Labs, who was incredibly helpful and responsive, and said they'd tune it for a heavier rider before sending it out to me. Hopefully it's an improvement for me too.
    Feb 2017
    For the price I would snag the fox up.
    https://rover.ebay.com/rover/0/0/0?m...2F122831088592
    Jan 2016
    I replaced the Monarch with the Fanatik tuned Fox DPS. A dramatic improvement, well worth the $$. Next up is the Following MB, so I guess I will have a Large gunmetal frame with both shocks for sale soon.
    Nov 2012
    Just bought the fox....What recommendation for pressure vs monarch ? Was 235 on avalanche monarch. Going home to install it now and ride
    Sent from my SM-N950U using Tapatalk
    Mar 2013
    Quote Originally Posted by exploder View Post
    I'd be curious to get some feedback on this too.
    I was 290psi on the Monarch Debonair. I don't get the chance to ride MTB much so I was hoping for a ballpark so I don't have a months worth of riding before it's dialed.
    Feb 2017
    With the Fox, smallest volume reducer and the RWC up top Iím running 255psi, I weigh 195# geared up.
    Nov 2012
    I weigh 170 and ran 235 previously and 220 felt good on the new fox with rebound 5 clicks from full fast
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    Edit: Oops, wrong thread.
    Nov 2012
    Would anyone like to buy my Avalanche Tuned monarch with rwc needle bearing kit now that I bought the fox. 100 bucks and it's yours. 3 months ride time on it.
    Feb 2016
    You like the Fox better then the Avy tuned Monarch? Just asking because I'm on the fence about getting the Fox Shock or having my Monarch tuned.
    Nov 2012
    I've only had one ride....I think the monarch pedals a little better and has more pop but the fox is smoother. If I did more pedaling I would keep the monarch.
    Feb 2016
    Thanks for input.
    Nov 2006
    Sent you a PM!
    Evil Following
    weareelements.com
    Nov 2012
    Replied
    Mar 2013
    New shock showed up today, didnít know I was getting the EVOL model. Should I get the smaller air can right off the bat? Heard EVOL is bad for heavier riders
    Mar 2013
    My outgoing Monarch only used ~80% of the travel (overall length vs o-ring at bottom out) but the new Fox uses ~95% of the shock body. Is this normal or was one of my shocks the wrong size?
    Feb 2017
    Winter/snow where I am but from what I can remember the o-ring goes to middle of the K on the Kashima logo when bottomed out.
    Quote Originally Posted by Rngspnr View Post
    This;
    This too;
    Just to clear this up we see many RT3's and Plus shocks damaged due to lack of maintaining the air can seals as dirt and debris can get under the air tube dust seal and score up the air tube/shaft anodizing. The heat comment was that in general air shocks can over heat on extended DH runs causing air pressure to build up too high and contaminant the damper oil with high pressure air, no permanent damage generally.
    Feb 2016
    Quote Originally Posted by crseekins View Post
    Thanks Craig. The information I got was second hand.
    Hey Dude! I am so sorry to hear you had a bad experience with us in the past. We absolutely try our best to be rider-oriented in all of our service, tuning, and upgrade/trade-in efforts.
    I am curious to hear more of how we can do better. Shoot me an email! Chris@dirtlabs.com
  1. Evil Bikes: The Following Ė User Review
    By ducrider in forum Evil Bikes
    Last Post: 6 Days Ago, 04:58 AM
  2. Replies: 4
    Last Post: 11-11-2017, 12:23 PM
  3. Replies: 46
    Last Post: 06-09-2017, 01:24 PM
  4. Evil D.O.C vs Evil Sovereign
    By woodc in forum All Mountain
    Last Post: 02-07-2011, 11:13 AM
Members who have read this thread: 39
