Fox DPX2 on following?- Mtbr.com
Results 1 to 23 of 23
    Does anybody know if the new Fox DPX2 shock will fit on a following? It's available in 7.25 x 1.75...
    Reputation: PurpleMtnSlayer's Avatar
    Jun 2015
    I don't know specifically for the following. But I called evil this week to get an air shock recommendation for the Wreckoning and the guy said wait for DPX2 over the new ohlins, CC and X2.
    Reputation: Energ8t's Avatar
    Sep 2013
    Quote Originally Posted by sandwich View Post
    I was under the impression that shocks with reservoirs wouldn't fit the Following. The frame has limited room due to the front derailleur mount, so the frame is shaped differently than any other Evil bike.
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    Would more interested to hear a DPX2 on a Wreckoning
    Santa Cruz Hightower LT
    Reputation: slim2none's Avatar
    I have wondered this same thing since seeing it. Evil and Fanatic both told me it probably wouldn't fit, but haven't tried it yet either. I would really like to know for sure.
    Sep 2013
    Quote Originally Posted by slim2none View Post
    I own a Following. Did you read my comment above? See pics below
    Sep 2013
    You can see how close the seat tube is to the shock due to the front derailleur mount design. Pretty tight.
    [QUOTE=Energ8t;13223476]I own a Following. Did you read my comment above? See pics below
    I did see your comments and I own a Following and a tape measure as well. Have you actually tried fitting it the shock? Obviously not-so I ignored your comments.
    Sep 2013
    [QUOTE=slim2none;13223547]
    Quote Originally Posted by Energ8t View Post
    Actually I didn't comment to offend you, I just asked and I don't find your attitude necessary. I am curious as everyone. Is there a reason why we can't have a discussion here without being courteous?
    Jun 2015
    [QUOTE=Energ8t;13223579]
    I hope it fits.
    uh, not trying to start a fight, just wondering if the shock was shaped so that it fit the frame. The following is a wildly popular frame, so I would think that a company would want to get in on the aftermarket for it (cane creek inline coil). Not much out there for replacements with adjustable compression
    I completely agree. It was intentionally designed/sized to be more compatible with a wide variety of frames. Let's hope it fits...
    Jan 2016
    Unfortunately the DBCoil IL doesn't fit at the top mount (at least on the Wreckoning) because the top of the shock is too wide to fit between the linkage. I am pretty sure the Following is the same width or smaller, but I can check. I bought one for my Wreckoning but had to send it back and get the DBCoil CS instead. The DBCoil CS is fantastic.
    Reputation: titusquasi's Avatar
    Quote Originally Posted by PurpleMtnSlayer View Post
    I've been eyeing the X2 for my Wrecker but became curious about the DPX2. This is just what I wanted to hear. Do we know what it's PSI max will be? Hopefully higher than the 250 psi of the X2.
    Jun 2015
    Quote Originally Posted by titusquasi View Post
    To be clear we were discussing trail shocks, he might recommend the X2 for dhing. I want a light weight trail/poppy shock and have a tuned coil for plowing.
    Mar 2012
    Found this pic on FB. DVO Topaz on small frame.
    Reputation: LyNx's Avatar
    Since these a re a bit more popular now, wondering if anyone has actually tried to fit one and cycle the suspension?
    Anybody got a review of this shock?
    Also what size would I need for the Wreckoning?
    Tia
    LCW
    LCW is offline
    Quote Originally Posted by neilingle View Post
    Tia
    The shock itself is sick. Very plush, but doesn't blow through. Climb switch has actual usable positions and the rebound knob access is great (vs old Float X). Running it my HT LT, not Following however. Different suspension between the two so can't comment if it fits or if it works well on a Following.
    any update on this?
    Feb 2017
    Wondering same thing
    I have heard Fox has the Trunion mount X2 in the works but it could be a while...
    Dylan from Evil checked with the product manager. No piggy back shocks will fit in the Following V1.
  1. New Fox DpX2 shock
    By yeti575inCA in forum Shocks and Suspension
    Last Post: 4 Weeks Ago, 06:03 PM
  2. Ripley LS shock: Fox DPX2
    By cgnreno in forum Ibis
    Last Post: 10-03-2018, 06:11 AM
  3. Fox Float DPX2
    By junior77 in forum Yeti
    Last Post: 06-14-2017, 10:02 AM
  4. Following with Fox Float DPS Rear Shock?
    By AllMountaineer in forum Evil Bikes
    Last Post: 04-21-2016, 07:12 AM
  5. new following thread - Uprising Vs Following
    By Dude! in forum Evil Bikes
    Last Post: 06-09-2015, 08:38 PM
Members who have read this thread: 13
