The Following - so far, so good?- Mtbr.com
Results 1 to 25 of 25
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Thinking SERIOUSLY of pulling the pin asap on an X01 build kit The Following. I appreciate it's early in the game, but has this bike been relatively problem-free so far?
    I have to drop a fair chunk of change on it because I'm from Canada, and the Canadian dollar is currently in the toilet.
    I'm aware of past issues with different Evil bikes. Just wondering if it looks like the reliability/durability thing has turned around for them.
    Very very interested, but still a wee bit nervous.
    Thanks guys. Much appreciated.
    Reputation: Tenacious Doug's Avatar
    For the most part, yes all good. I'm aware of 3 problems with rear ends causing issues, one through contacts in the UK, one that was reported on here a while back, and one I heard through the grapevine. Doesn't seem to be major issue considering the quantity sold. While I wouldn't say they have done enough to put any doubts out of mind now, for the most part things are looking solid. Mine has been all good!
    Mar 2015
    Quote Originally Posted by Tenacious Doug View Post
    For the most part, yes all good. I'm aware of 3 issues with rear ends causing issues, one through contacts in the UK, one that was reported on here a while back, and one I heard through the grapevine. Doesn't seem to be major issue considering the quantity sold. While I wouldn't say they have done enough to put any doubts out of mind now, for the most part things are looking solid. Mine has been all good!
    Thank you. Much appreciated. The The Following sounds like the perfect bike to complement my other bikes.
    Reputation: jazzanova's Avatar
    Quote Originally Posted by mtnbkrmike View Post
    Which other bikes do you have?
    Mar 2015
    Quote Originally Posted by jazzanova View Post
    My go to trail bike is a completely rebuilt 2015 Norco Range C2 (27.5 lbs). My back up trail bike is a 2006 Scott Ransom LTD (still functioning 100%). I also have a Kona Operator, a winter bike (a Kona hardtail) and a C-Dale cross bike.
    My Range is awesome but perhaps a little burly for the fast, buff, bermy stuff I often blast.
    Reputation: manitou2200's Avatar
    I spoke with Jaydn at Fanatik Bike a few weeks ago and the Following is their best selling bike ever and when we spoke they had sold 130-140 Followings since the beginning of the year. I asked him how many returns they had had and he said one, I don't remember what the issue was but I think he said it was a cosmetic flaw in the paint. They have seen no trends of problems or poor quality in the manufacture of the frames.
    Function in disaster, finish in style.
    Jan 2015
    One thing to add. My Following is on a truck, heading my way from Fanatik. While they were building it up they found that the adhesive that was meant to hold one of the cable guides inside the swing arm had given away. They quickly got a new swing arm from Evil, and finished the build. Spooked me a little, but they said they have seen this a couple times, and it's a very minor issue, nothing to worry about wrt the integrity of the frame.
    Reputation: Colin+M's Avatar
    I had the same issue on my Following. It was purely cosmetic, but they sent me a new rear triangle...no questions asked.
    Mar 2015
    Quote Originally Posted by Chickenbaby View Post
    I wonder whether I should order it from Fanatik instead of directly from the Evil headquarters... Hmmm...
    I'd deal with Jadyn at Fanatik. He's great.
    Sent from my VS980 4G using Tapatalk
    Quote Originally Posted by Colin+M View Post
    Colin, You had one from the first production run correct?
    The things that I'm seeing that impress me are the running changes Evil is making in the production runs. They are quickly addressing issues like the loose and rattling internal cable guides at the DT & BB, the rear axle and others I'm sure.
    My bike's been great but I found and corrected the internal guide issue when I was building it and then replaced my axle with the Ibis Hexle.
    I had a XX1 crank set on my Following with the SRAM BB. I did not like the fit of the BB into the Following and I could not torque the crank bolt to the spec, if I tried to it would bind and not spin freely. I needed a new 1x crank on another bike that has a SRAM threaded BB so I'm using the XX1 on that bike. I installed the Next SL crank and BB on my Following and I really like the BB fit and the cranks. Full torque on the crank bolt super smooth spinning and 130 grams lighter than the XX1.
    I had one of the first ones. I really liked the RF BB as well, spins very nicely.
    Jan 2015
    +1
    It's also really nice to be able to be able to precisely pick just about every component with the custom configurator: Evil The Following Custom Configurator - Fanatik Bike Co. - Bellingham WA
    If you want to see how some of your choices will actually look on your Following, click the Evil link in the build gallery: Fanatik Bike Co. - Build Gallery | A Collection of the Finest Mountain Bikes on the Planet
    The "Ship 'n Ride Business" option is pretty sweet. When mine arrives on Tuesday at work, I'll pull it out of the box and head straight for the trails.
    Mar 2015
    +1
    Wow. Thanks for the links. Those are both totally awesome.
    It's way more fun to pick out all the components and then build your bike, then ride it and test it and tweak it right out your back door on trails you built. Bike building is zen riding! Plus then you know everything is tip top!
    Mar 2015
    Quote Originally Posted by manitou2200 View Post
    Ideally. But I work, among many other things. Any spare time I have I'd rather be ridin than wrenchin. I unfortunately don't have time for both. I know exactly what I want though and that whole Fanatic website with the links has ripped this wide open. I think I will be going that route. I just need to figure out how to get it as they won't ship to Canada. Maybe a road trip is in order.
    Yeah, I work also, I'm pretty sure we all have to work especially to afford our habits, like biking, skiing and many other things. Building bikes is pretty damn simple and doing your own work will free your time because you won't be waiting for a shop to schedule you in. I run my own businesses and I make time to do my own work because I like it and I know it's done right. I don't know your situation but if you're a good rider you need to do your own work unless maybe you're sponsored.
    I learned to wrench mainly because I was too impatient to wait on someone else to do it for me.
    Mar 2015
    I have a good deal going on. My LBS doesn't charge me labour. I get minimum 25 points off parts (and anything else). And I jump the cue for anything I need. I can walk in unscheduled for any adjustment, replacement or repair for any of my bikes (or my daughter's), and 1 of the 3 top mechanics look after me, within 3 minutes. I am 100% loyal to my LBS, I have spent a lot of money there and over the years, I have come to know the owners really well. Its a quid pro quo situation. I am actually going to find out tomorrow if I can buy the Following through them. I am assuming not, which is why I am leaning towards Fanatik. I will be up front with them about it though.
    Sounds like you've got it figured out! Good on ya! Support your LBS!
    Mar 2015
    I hope I didn't sound like an ass saying that, but that truly is how it is. Plus I am pretty brutal when it comes to anything mechanical.
    Anyway, back on topic, I am going to see what is up with The Following with my LBS tomorrow, and then make a decision.
    Nope. Fanatic is great but if you an give the biz to your LBS all the better!
    I have a great relationship with my LBS, I ordered the frame directly from Evil and had my shop shop build it up for me.
    Mar 2015
    Quote Originally Posted by pking View Post
    Perfect. WTF was I thinking? I was going to see if I could go through them and have them order a built bike from Evil for me. That doesn't even make sense. Wow.
    nearly 500 miles and I had an issue, yesterday. went over a smooth roller jump, smooth landing and heard a pop!
    the top shock bolt snapped on the drive side. a new one is on the way from Evil as well as the updated axle. they said the early bikes had alloy bolts and had some break. now they have steel.
    it broke right at the start of the threads, and i was able to get the threaded part out by hand using the broken bolt.
    other than that, the bike has been perfect, and i would have no problem buying another evil bike.
  1. Replies: 54
    Last Post: 06-07-2014, 06:24 PM
  2. looking for good bang/buck ratio and quality. whats good?
    By car bone in forum Lights and Night Riding
    Last Post: 09-27-2013, 04:01 PM
  3. delete
    By actin in forum Urban/DJ/Park
    Last Post: 06-11-2013, 02:54 PM
  4. Replies: 1
    Last Post: 07-13-2012, 09:06 AM
  5. 1988 Solo MTB Adventure, Australia... Good times, good memories
    By digitalhippie13 in forum Riding Passion
    Last Post: 06-10-2011, 09:37 AM
