The Following Headtube/Headset Question- Mtbr.com
Results 1 to 5 of 5
    May 2017
    Not an experienced bike mechanic by any means, and looking for some help with this thing...trying to install the headset in a new Following frame.
    The top of the head tube has a cup pressed into it for the upper headset bearing to sit in, but the bottom of the head tube has no such thing...there is about 5mm play all around the bearing. It seems like the frame is missing a pressed in cup in which the lower bearing should sit.
    Is this correct? If so, and it should have been installed by the factory, can these be pressed in after the fact, or is it something that must be done during manufacturing? Thanks for any help!
    The Following Headtube/Headset Question-img_1722.jpg
    nel
    nel is offline
    Jun 2012
    Yes you are missing the lower headset cup. Mine came with it already installed but it can be pressed in with a headset press just like on any other frame.
    May 2017
    Thanks very much...appreciate the info!
    Learning to jump
    Jun 2015
    Quote Originally Posted by jab253 View Post
    Call a evil. They will probably fedex you the part.
    2015 Evil Following
    May 2017
    Thanks for the suggestion, I did just that...they fixed it faster than instantly Great customer service!!!
  1. headtube/headset tolerances
    By FireLikeIYA in forum Bike and Frame discussion
    Last Post: 04-07-2015, 11:50 AM
  2. Replies: 2
    Last Post: 08-20-2013, 11:19 PM
  3. Replies: 3
    Last Post: 08-17-2013, 02:37 PM
  4. HELP...Tapered headtube....headset question??
    By Francine in forum 29er Components
    Last Post: 07-09-2012, 07:01 AM
  5. Which headset for 1.5" headtube?
    By pixel_nut in forum Beginner's Corner
    Last Post: 07-04-2012, 06:54 AM
