Page 7 of 8 FirstFirst ... 345678 LastLast
Results 601 to 700 of 727
  1. #601
    Mar 2014
    Quote Originally Posted by VelkePivo View Post
    I've never understood this philosophy. Don't the trail conditions matter? Taking Whistler as an example, I would want to use all my travel on a gnarly tech line like Goat's Gully but not on a smooth easy jump line like Crank It Up or Blue Velvet. I'd rather have something in the tank for when I overshoot a jump or case one or the like.
    If you're riding in smoothish or otherwise not-so-challenging terrain, if you set up your suspension so you use all of it, won't it be too mushy? Can you push off it to jump? Don't you have to then reset it for when you hit a more challenging trail?
    Genuinely asking...
    This is always my philosophy... I set up my bikes to be fast and fun and use 90% of their suspension travel on a typical fast fun ride. The 10% buffer is for above and beyond rides, and screw up ups.
    I ride with guys that bottom their 160mm forks on the same trails I'll hit at speed on my fat bike or a hard tail... Then they wonder why they're tapping out on the real gnar.
  2. #602
    anybody ride this thing in 27.5 yet?
  3. #603
    Reputation: manitou2200's Avatar
    The Evil OFFERING....
    Genuinely asking...
    Can you control compression damping on your suspension? I think that should answer your question. You canít tune sag, psi for worst case. Or youíll only be using 60-80% of available travel. When it gets stout you increase comp damping. I think riders are too hung up for the most part in sag %. Whatever, you change it a bit for conditions either by psi or pre-load. Whatever works best for whatever youíre riding.
    When you have jump lines flowing into drops, doubles step downs and step ups you want to have it all. I donít like clanking it. But itís surprising what you can tune for.
    Use it all just not all the time.
    Function in disaster, finish in style.
  4. #604
    Reputation: Stupordave's Avatar
    Jan 2003
    Hard to believe Iíve had this sitting in my office for the last 3 weeks. Hopefully one more week and the last piece of my build will come in and I can get it built and on the trails.
  5. #605
    Oct 2014
    I am looking to replace the GX cranks on my offering, with either X01, XX1, or some Next R cranks.
    Unfortunately I am dumb when it comes to this stuff.
    If I stay with SRAM, do I have to get the DUB crank, or can I go with the other versions? If I go with the other versions, will I need to replace the 73mmBSA bottom bracket?
    What about "boost" or GXP versions? I was told if I go with GXP version, I will not need to replace the BB, and there is no need to buy the boost version?
    I could get a good price on a race face next r crank and bottom bracket. I know some do not recommend the RF BB. But if I went with the next r cranks, I will need a compatible BB. Can I throw any chainring on there? I am assuming when setting up the next r crank, it is just like setting any other crank up to align with Eagle?
    Am I making sense? Sorry, I know nothing about this.
    I found a decent deal on an XX1 Eagle crank (GXP). If I can use that without changing the default BB on the offering, I will buy that.
  6. #606
    Reputation: Pritchett's Avatar
    May 2005
    You will certainly want a boost spaced crank so that your chainring will fit in the chainguide. Make sure your cranks and chainring are going to create a 51-52mm chainline.
    If the gx cranks you have now are ďdubĒ cranks, any new ďdubĒ Sram cranks will work with your current bottom bracket.
    Saving a few bucks on ďoldĒ gxp spindle cranks means youíll need a gxp bottom bracket... and race face will require a BSA30 bottom bracket.
    Your chainring on the gxp crank would swap over to any Sram direct mount, but the x01 and xx1 chainrings are a bit fancier, if youíre on an upgrade rampage...
    A racface crank would require a raceface direct mount chainring.
    My thoughts are that youíd be best getting a dub crank if you must upgrade.
    My better question regarding the upgrade is, what problem are you trying to solve?
  7. #607
    Oct 2014
    no problem, honestly, just trying to make the best bike I can as the wife allowed me a nice budget. I want to move to carbon cranks, to save some weight.
    what is the BB on the Offering?
  8. #608
    Oct 2014
    What grips come on the bike? Is it the cheapo lock on evil grips, or the "palmerahanderson" grips?
  9. #609
    Nov 2015
    Quote Originally Posted by Stupordave View Post
    Drools.......
    Sent from my SM-G955F using Tapatalk
  10. #610
    I fix choppers
    Reputation: HELLBELLY's Avatar
    Quote Originally Posted by lardo5150 View Post
    The Following MB demos we received this summer had the Pamelahanderson's so I'd imagine the new kits will as well.
    As for cranks/bb's you can use whatever you want. The gains you'll get performance-wise from switching from the GX to XX1 are minimal and as a big guy as you've mentioned elsewhere, I recommend you save your money. If money is no object then buy some Cane Creek eeWings where you'll get light and strong, but not cheap.
    "Everything popular is wrong." -Oscar Wilde
  11. #611
    Oct 2014
    Quote Originally Posted by HELLBELLY View Post
    wowser. $1000 bucks.
    I dont have that much money to burn, LOL. Thanks for the link though.
    Ugh, I just ordered some of those grips from JensonUSA. I have a year to send them back so no big deal, just annoying.
  12. #612
    I fix choppers
    We're all big guys here (in Georgia) and while some have XO cranks (that came with those kits) most of us have the most basic cranks available. I personally run X1 cranks and they've been trouble free. If I were to replace them I'd get another set of those or some Canfields.
    Lotsa great grips to be had, but grips are like underwear and everyone has their own style. FWIW, I really like the Thick DMR Deathgrips.
  13. #613
    Oct 2014
    OH, I like those, I did not see those before. I might swap out with Jenson. THANKS!
  14. #614
    Oct 2014
    https://www.bicycling.com/bikes-gear...fering-review/
    Overall good review, but I disagree about not being playful. I found it easy to move around.
  15. #615
    Reputation: SikeMo's Avatar
    Mar 2013
  16. #616
    Oct 2018
    Thanks for posting. To be fair, unless I missed it the author didn't say the Offering wasn't playful, just that the increased length "reduces some of the exceptional pop and live[li]ness that the Following and Wreckoning known for." To me that's an all-but irrefutable reality of physics. There's a reason DJ bikes and DH bikes aren't the same lengths. Unfortunately, there's just no escaping compromise when it comes to bikes.
  17. #617
    wretch
    Reputation: Truckee Trash's Avatar
    Has anyone seen information posted about seat tube insertion length - specifically looking at the XL. . . Thanks in advance!
  18. #618
    Reputation: Dude!'s Avatar
    FYI - now that I know that I really like the Offering. I will be tinkering with the different fork offsets. I initially purchased 160mm Fox grip2 with 44m offset. Through trying different combinations, I have ended up with the fork at 150mm in xlow. I went with the 44mm offset that this was going to be my big bike set-up with longer travel would potentially make the 44mm more appropriate. Now that I am using this as my go-to bike, the 51mm fork offset has been bugging me.
    Furthermore, Evil's strong recommendation for the 51mm has remained spinning in my brain. Kevin W. provided me with some good feedback that I would like the 51mm offset.
    Therefore, instead of purchasing a CSU with a 51mm offset, which costs about 50% of the fork, and requires swapping fork inners and lowers. I decided to purchase a 51mm grip2. This way I can do back to back testing (the scientist in me is curious) and it will be much easier to sell a whole fork as oppose to just a CSU.
    More to follow....
  19. #619
    Dec 2017
    Quote Originally Posted by Dude! View Post
    More to follow....
    Sounds good. I am between a 140 and 150 fork.
    You also owned a pivot switchblade? I would like to know how pedaling efficacy compare between the two (I ride a pivot now).
  20. #620
    Oct 2018
    More to follow....
    I debated myself for a while on which fork offset to go with for the Offering and ultimately decided on the 150mm/51mm Lyrik RC2 based on Evil's strong recommendation and that the bike was designed around that offset.
    I'm curious if anyone is going to run DVO front and rear now that they offer a metric trunnion shock in 185x55.
    2019 Evil Offering (on order)
    2019 Evil Wreckoning LB
    2018 Orbea Occam TR 27.5
    FOR SALE 2017 Pivot Switchblade Carbon
  21. #621
    Feb 2014
    Quite a few rides in and not one pedal strike.. time to try xlow I think.
    Sent from my Moto G (4) using Tapatalk
  22. #622
    Oct 2014
    So I was chatting with Evil, and they mentioned this:
    "Don't forget you can tweak that Offering in a number of different way. The default fork offset is 51mm but you can also run 43 or 44mm fork offsets to increase the level of tight handling possible with all out trail shredding performance!"
    I thought if you shorten the offset (from 51 to 44), you are actually INCREASING trail, and in theory, making the turning worse?
    They mentioned the above to me because I had told them I was trying to choose between the SB130 and Offering, and ended up going with the Offering, but if they update the geo on the Following, I would be in a world of hurt (because I would have to buy that bike also, lol). So they mentioned that above.
  23. #623
    Reputation: oldsklrdr's Avatar
    May 2012
    https://www.mbr.co.uk/news/fork-offs...e-trail-342679
    Summarizes it so i donít have to type
    Itís a bit Ė but not exactly Ė like having a steep or a slack head angle. Lots of trail results in more stable steering but it also results in the front axle being a bit closer to you. So for all-out straightish speed sections the bike will feel shorter. But on twisty hairpins in steep terrain the bike will carve calmer and hold its line bette
    Read more at https://www.mbr.co.uk/news/fork-offs...kkOfCzG00DL.99
  24. #624
    Oct 2014
    ok ok, so....
    If I keep the offering at a 140m fork, but I decrease the offset from 51 to 44, I will be shortening the wheelbase, thus making the bike turn more easily, maybe even twitchy?
    What about a 150 up front, with either a 44-41 vs 51?
  25. #625
    Oct 2014
    ok, I THINK I have the above post backwards.
    This video was helpful.
    https://www.youtube.com/watch?v=YxbR4OjHeCU
  26. #626
    Oct 2014
    ok, think I got it now (that video was helpful).
    If I throw a 150 on there, the HA is decreasing (66.6 to 66.2), thus increasing trail, more stable.
    At that point i would have to increase the offset from 51 to something else to make it feel more "twitchy" (dont even think we can do that). Reducing the offset with the 150 fork from 51 to 44 or something, would make the steering even more "lazy"?
  27. #627
    Evil recommends a 51mm offset. The offering doesn't have a very slack head angle so i'd go with 51. I think the short offset forks make sense on bikes with very, very slack head angles.
  28. #628
    Quote Originally Posted by jwren00 View Post
    Not true... There's companies out there suggesting shorter offsets are better with steeper HA's as well as slacker! The "offset war" as I'm calling it seems to be driven more by the marketing men than it does actual science, I've spoken with designers of bikes about the pro's and con's of different fork offsets, and it all comes down to what you're trying to achieve I guess...
    I haven't conducted true "back to back" tests, but have a fair amount of experience running 29ers (lots of them in fact, from 100mm to 160mm travel and everywhere inbetween) over the last 6 years, several with 46mm offset, several with 51mm offset and currently one with a new 42mm offset Rockshox Pike... Remember that the 51mm offset was a fairly recent introduction to the market (around the time the original Following came out, so back end of 2014/early 2015) that was pushed by the marketing men at Trek as they were desperately trying to make their 29ers more agile so that people coming from 26" wheels would buy them... But that's besides the point...
    What's the difference? Well, in honesty, not that much! A 5mm increase or decrease in trail on the fork won't ruin the bike for sure... It's very subtle changes at most.
    What I will say from experience is that the 51mm offset tends to steer a little quicker, but is less adept at holding a line (trail chatter and bumps will throw it off line easier). The 42mm offset is noticeable in how well it holds a line through the rough stuff, but at slower speeds it does require a little more effort to turn tighter corners, but when I say a "little", I mean a little... It's not huge differences! The 46mm middle ground forks, are, as you'd imagine, somewhere inbetween...
    It's kinda like when the wheel size debate exploded... If you like twitchy, fast steering bikes, you'll always prefer 26" wheels. If you like super stable and hold their line and speed through the rough stuff, you'll prefer 29ers. For the middle ground, there is of course 27.5...
    My 2penneth, if pushed... I'd say that on a shorter travel trail or XC bike, maybe 100-130mm up front, the slightly sharper steering of a 51mm offset can be preferential sometimes. What I found at the other end of the spectrum, was that on my Evil Wreckoning with 160mm up front @ 51mm offset, I would often feel like the front was going to tuck under (and it did a couple of times) without enough weight over the front wheel, which demanded a slightly more over the front agressive riding style and a distrust in most tyres I tried up front on it except for the Schwalbe Magic Mary. I would like to have tried a 46 or even shorter offset fork on that bike to compare, but sadly didn't get the opportunity. The 42mm offset fork I have on my current Whyte S-150 C RS inspires more confidence (head angle and other geometry almost identical for what it's worth) in that respect...
    My Offering frame should be with me soon, I've picked up a Fox 36 Factory 44mm offset @ 160mm travel to go on it. I'll either run it with a lot of sag and plenty of volume spacers or shorten it to 150mm I guess, but I'm convinced for what I like and how I like my bikes to feel, the shorter offset will be better for me. If it feels crap, I'll just swap it out for a 51mm CSU and be done with it, but I'm confident it will be what I want...
  29. #629
    Reputation: boomn's Avatar
    Quote Originally Posted by markyboy1980 View Post
    FWIW Gary Fisher started the "G2" 51mm offset around 2007, back when the couple available 29ers forks had a 38mm offset! It was a big jump, but a welcome innovation in trying to figure out how to make these promising 29" wheels not handle so terribly. They were also one of the first brands to take steps in slacking out head angles, shortening chainstays, lengthening top tubes to run shorter stems. It was baby steps compared to where we are now, but it was radical at the time!
    When Fox released their first aftermarket 29er forks a year later they went with a middle-of-the-road 44mm offset
  30. #630
    Quote Originally Posted by boomn View Post
    Still have my Fisher Roscoe, canít bring myself to get rid of it for the reasons stated above. The bike has seen a couple different forks/travel up front and is pretty versatile. I still take it out once in a while and it rips. Plan to put an updated shock on it eventually and keep it in the quiver. Sorry for the hijack.
  31. #631
    I fix choppers
    The offset wars...excellent! In my non-scientific research I found the Transition Sentinel be the the only long travel 29er bike that rivaled my Wreckoning. The Sentinel's cornering ability is next level. My biggest knock against it (and this would likely be gone after moving up a learning curve once you had it for a little while) was it's handling in tight slow speed nastiness. It was here that I could detect the longer wheelbase and had more difficulty getting the Sentinel to change course rapidly. As you note above, the offset likely plays into this. In the tight nasty east coast riding it would require some rides to learn how to predict where this will become an issue. However, on the contrary I have also learned how position myself with panache on the Wreck to manage sweeping turns and not wash out. I give the Sentinel the edge in theses turns.
    Finally, I know anyone can ride anything they want wherever they wish. I still prefer my Wreckoning as it excels in my environment and for how I ride. The Sentinel may be better suited for big open terrain, but I am sure many would dig it wherever regardless.
  32. #632
    Quote Originally Posted by bcall8 View Post
    I went with the RockShox. I spoke with Mike at Evil about the differences. He said that with this frame they have a hard time telling the difference in feel between the Fox and the RockShox. Very similar. He did indicate that the Fox required slightly less air pressure than the RockShox to achieve the same sag so it might be beneficial for heavier riders to get the Fox. The impression I got from the conversation was that it might be splitting hairs and go with the brand that you like or match your fork or whatever. Based on that I went with the RockShox mainly because it was all black. I have no experience with any Fox shocks on my Evils so I canít help there. I will say that for my weight I am running a much lower PSI on the Offering than I was on my Following MB to get in the 30% sag range. Right now I am at 250psi where as I was at 285 with my old bike.
    I know as others have suggested it probably doesnít really matter and will likely be imperceptible, but Iíve been thinking about this comment. I feel like you could take Evilís statement on air pressure necessary to achieve sag in two different ways, albeit both speculation.
    If the Fox takes less air pressure to achieve the same sag it has either a) more internal friction; or b) a stiffer LSC damping circuit. The first option is obviously detrimental, the second could go either way depending on your weight, riding style, and/or intended use and terrain.
    Anyone have other thoughts? Ridden both? Over analyzing!?
  33. #633
    Nov 2015
    Quote Originally Posted by rccp View Post
    Setting sag should not be affected by friction or the damping circuit. Both friction and damping only come into affect when movement is involved. If the shock isn't moving (which it shouldn't be when you're setting your sag) then friction and damping should not be in play. The pressures required to achieve similar sag numbers are much more likely a function of air spring volumes.
    With that said, the damping circuits are probably the biggest difference between Fox and Rockshox. They definitely feel different, but one is not objectively better or worse. In my experience Rockshox tend to feel very supple and responsive, but can blow through their travel quite easily. Fox shocks feel more supportive, but not as supple.
    In reality, you can probably get either shock to feel the way you want.
  34. #634
    Oct 2014
    I am curious how the bike feels with the 150 up front.
    My review based on my Outerbike rides were all 140.
  35. #635
    Mar 2013
    This is what I've been thinking, but then you've got bikes like the SB100 that are using the shorter offset. To me it's turning into marketing hype more than anything. Also, just another irritating reason reason that bike parts will have even lower resale values.
  36. #636
    Quote Originally Posted by PaullyD View Post
    Good points, totally agree in retrospect that the spring rate must be the same to achieve the same sag, therefore different pressures mean different air spring volumes.
    Your comparison between the two is valuable and reinforces my experience between the two brands, but Iíve never been on the Super Deluxe. Thanks for the insight.
  37. #637
    Oct 2018
    I went with the 150 fork and will let you know how it rides when I get the bike. I was torn between the 140 and 150 but ultimately went with the 150 because Rich at Fanatik said that the difference in ride dynamics is pretty negligible. I like the idea of having a little more travel in the front but still maintaining playfulness.
  38. #638
    Reputation: ChiliDog76's Avatar
    Nov 2013
    Should be getting this in a few days. Can't wait to get it out on the trails!!
  39. #639
    May 2016
    Quote Originally Posted by ChiliDog76 View Post
    Nice!!! 150 or 160 36 ?
  40. #640
    Reputation: NC Kingsting's Avatar
    Apr 2016
    Good looking bike! Thatís a pretty steep transition on the jump behind it though.
  41. #641
    Nov 2013
    150 I think 160 is overkill for my local trails
  42. #642
    Well, only one 10 mile ride with the 51mm offset fork, as I have been riding the 44mm offset fork for the last few weeks since getting the Offering. The short ride was because of the amount of smoke in the air from the Cali fires. Anyway, I prefer the 51mm offset fork, its more playful. As most folks have already stated, the difference is subtle but noticeable.
    BTW - I will be selling the 44mm offset fork if interested 2019 GRIP2 36 150mm boost 110 - only a few weeks old in great condition. PM me if interested.
  43. #643
    Nov 2018
    Sizing
  44. #644
    Feb 2015
    Hey all
    A few notes since building up my Offering last week..
    The tolerance around the crank is VERY tight. After trying them all, here is is a list of cranks that DO NOT FIT: Quarq XX1 Dub, rotor Rex 1.1, Shimano XT, sram gx bb30.
    The bolts on the trunion mount keep coming loose.. 5nm is not a lot of torque. So check yours!
    re: sizing, I was so worried this wasnít going to work. Iím 183cm tall, with a high ape index. I sized up to an XL Santa Cruz tallboy, so was seriously worried about going back down to a large Offering. It was 100% the right call for me! If anything, the large offering may even feel a little longer than my xl tallboy. N=1.
    I jacked the fork down to 140 to start with. About right for the style of riding that I do, for now.
    i also fitted my 650+ wheels to see if that would work. 45mm ID with Maxxis Rekon + tyres. They fit, but the lateral tolerance is a bit Toit for my my liking. Will probably get a set of the 2.6s if I want to run these in late summer when the trails are blown out.
    The final build with a 36 factory fork, fox dpx2 shock, gx Grouppo, race face carbon bars, pedals, cages.. the works comes in at 14.93kg.
    very, very happy with how this bike turned out. Was between this and the yeti SB130. I got this, my buddy got the yeti.. and weíre both stoked. Difficult to describe without using a string of cliches, but it feels really responsive and lively on the smoother stuff, but the second that you hit the rough stuff.. itís like a different bike. Really plush and soaks it all up.
    just my 2c. Shout if there are any specific questions, and Iíll try answer if I can.
    tx,
    Jean
  45. #645
    Oct 2014
    Quote Originally Posted by JeanDiv14 View Post
    Hey all
    tx,
    Jean
    how tall are you?
  46. #646
    Feb 2015
    183cm, as above.
  47. #647
    4th paragraph
    breezy shade
  48. #648
    Oct 2014
    missed it, thanks!
  49. #649
    May 2010
    Wait, are you saying the boosted Shimano XT cranks don't fit? What cranks actually do?
  50. #650
    nel
    nel is online now
    Jun 2012
    Quote Originally Posted by biggrumble View Post
    The boost Shimano XT fits fine. The non-boost Shimano XT doesn't fit as the chainring contacts the chainstay. I tried both.
  51. #651
    Feb 2018
    Update...
    Although the weather hasn't been overly cooperative I've been able to get a few additional rides in. Here's a quick update:
    • I'm 6'2" with a size L. I can't stress enough that I am so glad I did NOT size up.
    • I absolutely LOVE the playfulness of the Offering. This bike feels like it rides "lighter" and is more "flickable"... if that makes any sense.
    • This bike climbs exceptionally well even on more technical terrain. Compared to my XC rig, I really don't feel like I'm giving anything up on climbs.
    • After tuning the suspension a bit I no longer have an issue with pedal strikes.
    This bike has me feeling (more) like a kid again. Can't wait to ride again!
  52. #652
    Oct 2014
    Quote Originally Posted by rmap01 View Post
    Do you normally ride a large? At 6'2 according to their size chart you should be a large. Any reason why you were thinking xl?
  53. #653
    Feb 2015
    Quote Originally Posted by nel View Post
    Yeah, the non-boost Shimano did not fit. In the end, I fitted a sram gx dub with a 3mm offset chainring (the 6mm one did not fit). A lot of driving around in the middle of a work day :-)
  54. #654
    Apr 2016
    Oh crap. Think I have a problem. Based on what you are describing the 51mm chain line quoted in the Specification section of the Evil website appears to be wrong as boost versions of the XT crank have a 53mm chain line. Can anybody confirm what is right.
  55. #655
    Feb 2015
    All my bikes before my tall boy had been large. I sized up on the tallboy after demoing both their large and XL. I could have ridden either, tbh.. On the fence, but I put on a 50mm stem and some 800mm bars, and was really happy with the end result.
    After pouring over the offering geo comparisons for some time, I went with the large Offering, and prayed. It has the same reach as the xl tallboy, but a slightly shorter TT (steeper sta). In my head I thought Ďsame cockpit size when standing in descents, slightly shorter when climbing seatedí. Was worried about the latter. After riding it for a week, I can tell you that the slightly shorter cockpit while seated is a complete non issue. I donít feel it at all, and I may even shorten the stem somewhere down the road. The bike feels bigger, and longer than my tallboy, but that is probably just to do with the slacker HTA rather than a point in space.
  56. #656
    Feb 2018
    Most other bikes would put me on a size XL. There's been a lot of debate on this thread - especially early on - about sizing up. When I was looking at the Calling a few months ago, they were out of the L (that would have been my size per their recommendation). When I contacted Evil about availability one of the guys told me a XL would probably fit but I figured I'd wait. Glad I did!
  57. #657
    nel
    nel is online now
    Jun 2012
    Quote Originally Posted by NC Kingsting View Post
    Yes that's right - you definitely need the Boost version of the XT M8000 single crank. The non-boost won't fit.
  58. #658
    As someone who is also 6 foot 2 I completely get this struggle. I'm always in between on sizes and prefer XL to L 9 times out of 10. As far as Evil's size chart goes, they say I'm a Large for the Wreckoning and Following MB but I've thrown a leg over both of those and am definitely an XL. The Offering however is a different beast altogether and I'm leaning towards large.
  59. #659
    Feb 2018
    Quote Originally Posted by JonathanM View Post
    While I've not ridden the Wreck, I rented the Following (size L) for 2 days. Felt slightly cramped for my taste. For me - wingspan comparable to my height - the Large Offering is spot on.
  60. #660
    Dec 2017
    Hey all
    tx,
    Jean
    Did you ride your friends yeti sb130? If so how does the pedal efficacy compare?
  61. #661
    Oct 2018
    Any idea what your cycling inseam is? Thanks
  62. #662
    Feb 2018
    Just under 36"
  63. #663
    wretch
    Here are the numbers I ran to decide on an XL
    I'm 6'3" - XL Wreck with 50mm stem and 175 dropper with about 1.5" of exposed post. Saddle pretty far back.
    Main fit measurements are
    Saddle Height 790mm
    Reach 570.6mm
    According to EVIL and my questionable math I can run a 185 Revive post and be good to go. I went with a 35mm stem but have a feeling i'll be going to 50mm.
  64. #664
    Oct 2018
    Just under 36"
    Same as me, although I find the large FMB just right. More precisely, maybe a tad tight when climbing but perfect when out of the saddle for the riding I like to do. I'm also somewhere right now where there's not a lot of high-speed riding, so maybe that factors into it. On the other hand, I spent two seasons at Whistler (mostly the jump lines) with the 17" reach on my dh bike and loved it. I tried a longer reach bike for a couple days but ditched it and went back to my bike. There are so many variables that I suppose only the roughest rule of thumb should be drawn.
    Most of my riding the past 10 years has been gravity focused. And my trail rides now are fairly short. Maybe if I did long rides the comfort of the longer bike would become more important to me.
    Just trying to figure all this out...
  65. #665
    Feb 2018
    FWIW, the trails I ride are on the XC-Enduro spectrum. 2.5 hours in the saddle yesterday. Comfort was not an issue.
  66. #666
    Oct 2018
    Hmm, my rides now are 1.5-2 hours and they feel short, or normal-short, to me. When I said long rides I had in mind 5 hours to all-day-on-the-bike kinda stuff. Of course "how long" a ride is will depend a lot on the terrain. Super rocky technical stuff where you're constantly ratcheting over obstacles and/or constantly running into square edged hits is really tiring. I find my Following to be pretty lousy on those square edged hits. I'm sure the Offering is much better. Must be a fantastic all-around bike.
  67. #667
    Feb 2018
    When I said long rides I had in mind 5 hours to all-day-on-the-bike kinda stuff...
    To be honest, I don't find any bike to be comfortable on 5+ hour rides. LOL.
  68. #668
    I rode the large Offering in Sedona all day. I am 6'3.5", almost 6'4". The large was barely too small. The XL is definitely my choice.
  69. #669
    wretch
    Quote Originally Posted by matixsnow View Post
    Music to my ears! Thanks for the info.
  70. #670
    Oct 2018
    I'm not a big fan of all-day rides, either; though it's great when they're over and they are memorable.
  71. #671
    May 2012
    Did you actually try to install all these cranks? I spoke to folks at Evil last night. They recommended XT non-Boost with a 1mm spacer. If these rings actually contacted the frame 1mm is not enough. What tooth chainrings were you using? Thanks!!
  72. #672
    Mar 2013
    PSA: Invisiframe now has M and L kits for the Offering.
  73. #673
    May 2012
    Hey all
  74. #674
    Jan 2015
    Am I the only one who ordered an Offering within 2 days of the announcement of the thing and *still* doesn't have a bike? Every couple weeks I hear it's just another couple of weeks. Okay, we're all loyal fanboys, but still, are these guys really running a business like this...?
  75. #675
    Mar 2013
    Nope. Still waiting here too. Starting to get anxious.
  76. #676
    wretch
    Mine shipped yesterday...believe they were received on Friday.
  77. #677
    Oct 2014
    Quote Originally Posted by Chickenbaby View Post
    Dude, basic supply and demand.
    The demand was overwhelming. Just not enough bikes.
  78. #678
    wretch
    I think there should be some kudos given to them for having a second shipment right on the tail of the first. Big brands will air freight for launches, press, etc. but smaller fish are usually left watching a boat, waiting on it in port, then finally receiving.
  79. #679
    I bought mine directly from Evil Friday morning as soon as it was announced as I knew this was going to sell out. I didn't bother with any shops etc as they add more time - went right to the source.
    Its well worth the wait!!! The bike is amazing!
  80. #680
    Jan 2015
    Quote Originally Posted by Truckee Trash View Post
    Understood. And to be clear, I ordered through Fanatik, so my gripe may have mostly (or entirely) to do with them. Still, the *repeated* slipping timelines (in the absence of production or shipping issues) doesn't make sense to me--it must just be a communication issue between some of the involved parties.
  81. #681
    Aug 2015
    Talked to a friend who works at Evil... suggested that the tariffs are killing them. It's taking up to a month extra to clear everything once they hit the ports. It sounds like they got a couple of shipments in late last week, and they should be shipping soon if not already out.
    Good practice for my lack of patience...
  82. #682
    Nov 2008
    The company I work for deals with shipping a lot of things from overseas. On a boat (or a plane if you pay the big bucks), there are constant delays. Then, once it finally gets to customs, it takes forever and you'll never get a firm date out of them. So, we usually tell customers what the shipper tells us, but it always gets delayed
  83. #683
    Mine should also be here friday and i just ordered on tuesday. Direct from Evil. Talked to them about ordering through a shop to save on shipping essentially and they suggested not to do that, as it would delay me getting a bike and possibly not get one. There is also a waiting list already in place for this second shipment. I imagine yours will be on the way to fanatik soon if not already there. They were still do QC on the frames on tuesday when I called in and luckily two blue larges had already cleared. Hope you have your bike this week.
  84. #684
    Jan 2015
    Quote Originally Posted by delarosa View Post
    ...about ordering through a shop to save on shipping essentially and they suggested not to do that, as it would delay me getting a bike and possibly not get one.
    The bit about not getting a bike is disturbing. I had a good experience ordering my 2015 Following through Fanatik, and I had some specific things I wanted on my Offering build this time around. But I guess I should have just gone with Evil directly. At this point it probably wouldn't help me to cancel my order with Fanatik, and place one with Evil...
  85. #685
    Mar 2013
    I'm also waiting on Fanatik. Cheap shipping and, most importantly, no CA sales tax, which adds nearly $300 to the price of the frame.
  86. #686
    Oct 2018
    Quote Originally Posted by SikeMo View Post
    Same here. I was hoping they would be able to fulfill orders with this most recent shipment of frames but now I'm not so optimistic.
  87. #687
    Feb 2018
    Quote Originally Posted by TrashPanda View Post
    Dude, too funny that you've already updated your sig with the Offering. But I appreciate your eagerness as I'm not the most patient person either. I was fortunate to get my order in very early as I kept checking the Evil site to see if the Calling (Large) was back in stock. When I saw this I jumped on it right away. Hope you guys all get yours soon. FWIW, the weather (in the NE US at least) has limited the opportunities to ride which kinda sux!
  88. #688
    Nov 2013
    Received mine Monday from Fanatik. It's a medium blue frame. Seemed like the only size and color they had in stock when I placed my order.
  89. #689
    Nov 2018
    Sizing question. Iím 6í2Ē. Large or XL. Based off previous bikes Iíd definitely go XL. Have a V1 following in large and had a large Insurgent. After having a large Sentinel for almost a year I now realize my following is too small. I was considering an XL wreckoning if this bike had not been released. I also want the DPX 2 option which hasnít arrived at EVIL yet so either way Iím waiting a little bit.
    So do I go L or XL... seems theyíve sized the bikes up??
    Opinions appreciated
    Can I pick someones brain on this?
    I'm just shy of 6'2", with an inseam of 93cm (about 36.6inches) and long arms,
    the XL Offering looks on paper to be the kind of bike I'm looking for.
    Would it be stupid to choose the XL over a Large?
    And Delarosa, did you end up with an Offering, if so which size did you go for?
  90. #690
    Feb 2018
    I'm 6'2 with an inseam just a shade under 36" and very pleased I got the Large as I don't feel cramped in any way and I find the bike to be quite playful. Obviously it comes down to what feels most comfortable for you. I'd suggest reaching out to the guys at Evil directly. They're pretty responsive.
  91. #691
    Sep 2017
    My Offering just shipped from Evil. Size is a small. Had a Following and loved it. Replaced it with a Wreckoning and now onto my third Evil. The Wreckoning is great but Iím just looking to switch things up and I dig the brand.
  92. #692
    Quote Originally Posted by movgard View Post
    Yes my Offering should be here tomorrow size large. Iím coming from a large Sentinel.
    Regarding my previous comment about ďnot getting ď a frame it sounded like if I went through my local shop I would save on shipping but give up my spot on the waiting list as they fulfill those orders and they wouldnít speak to quantities available to online retailers. I assume if you had already one ordered ďround oneĒ from an online retailer that they have probably accounted for you guys.
    Anyone able to confirm on full insertion on a large frame with particular seatposts?
    One up 170
    Fall line 175 or 200
    Revive 185
  93. #693
    Mar 2011
    I have a large offering and I cannot get full insertion with my bike yoke revive 185. If I remember correctly I still had about 15 to 20mm post showing at bottom out. However, for the saddle height that I wanted I have about 35mm of post showing so not being able to slam the post is a non issue for me.
  94. #694
    Robertson
    Reputation: rpearce1475's Avatar
    Jan 2015
    One up 170
    Revive 185
    Would be interested when you get it to hear your thoughts on Offering vs Sentinel. Why the switch if you don't mind me asking?
  95. #695
    Quote Originally Posted by Streetdoctor View Post
    Hey thanks man! That was a big day! They're a few months out from C3 it sounds like. I'm trying not to be impatient but.... new bike day!
    C3 is about a day or two out. Their fleet of demos plus a few for customers might be rolling in today actually. I've got a large frame coming in.
  96. #696
    Parts are all here.
    Large frame in blackout
    red lyrik forks @150 51mm offset
    oneup dropper
    Next R bars
    Next R Wheelset 36mm wide
    Minion DHF 2.5/Aggressor 2.5
    Code RSC brakes
    XO1 group w/XO1 170mm cranks
    I really hope the frame arrives today to be built for the weekend.
  97. #697
    wretch
    Parts are all here.
    oneup dropper
    Next R bars
    Code RSC brakes
    I'll play - was hoping for new XTR but a factory fire and other delays mean Eagle for me.
    Frame today, hang parts over the weekend, wheels arrive Monday.
    2019 Fox 36 Grip2 @140mm
    XL Black out Drunk w/ DPX2
    xx1 Eagle
    Guide Ultimate
    185 Bike Yoke Revive Dropper
    We Are One Agent Rims w/ Onyx hubs + Cush Core
    Schwalbe Magic Mary 2.6 front - hoping to fit a 2.6 Damf in the back.
    Deity BrenDog Bars, Stem, Grips and pedals.
    SQ Labs saddle - super super comfortable!
  98. #698
    wretch
    One up 170
    Revive 185
    250mm Max insertion on an XL frame ... EVIL has a calculator they ran these for me on the xl -
    XL Offering with-
    160mm BikeYoke Revive: 692.8mm
    185mm BikeYoke Revive: 742.8mm
    Both those numbers are minimum seat height. Measured BB center to Seat Rail center.
  99. #699
    Dec 2008
    A bit of an odd request for those that have an Offering in the hand. Would anyone be willing to take two measurements for me?
    1) Rear triangle pivot to flip chip pivot, eye to eye (preferably in Low and not XLow).
    2) Rear triangle pivot to Delta frame mount pivot, eye to eye.
    Thanks in advance....
  100. #700
    Quote Originally Posted by rpearce1475 View Post
    I will elaborate once I get my Offering built up. I had a Following and Insurgent before. Sold the Insurgent for the Sentinel (found I'm a 29er guy). Really like the Sentinel super confident feeling riding the bike, have a first run alloy version and was going to upgrade to carbon this year.
    I always said I'd upgrade to the carbon Sentinel unless Evil came out with a 140 29er. I just really like the way the evil bikes ride, no complaints about the Transition.
  1. Stolen Evil Bikes - Need Evil Nation Help
    By GFreak in forum Evil Bikes
    Last Post: 06-26-2018, 07:45 PM
  2. Evil D.O.C vs Evil Sovereign
    By woodc in forum All Mountain
    Last Post: 02-07-2011, 11:13 AM
  3. contours latest offering
    By delirian in forum Videos and POV Cameras
    Last Post: 01-13-2011, 04:41 PM
Members who have read this thread: 914
