Evil following SPECS- Mtbr.com
    Jan 2015
    So i got the frame today which comes with a raceface bottom bracket but my buddy took off hi turbine cinch cranks. I noticed that the spindle is bigger than mine which is a SLX crank. What bottom bracket will work with my existing shimano slx crank. Or i have no choice but to get a raceface crank too with a thicker spindle. I am not familiar with the spec i hope someone can enlighten me.
    also, which areas do i have to check regularly for scratches or cable rubs? What do you guys recommend to keep the frame fine
    Reputation: OldHouseMan's Avatar
    You will need a bottom bracket that will fit a PF92 frame and 24mm spindle. There is a pretty good selection of BB's that will work. Shimano, Hope, Chris King and Enduro all make something that will work. There are probably many more that will also work.
    The selection of BB's gets limited when fitting a 30mm spindle into a PF92 shell. Race Face, Hope and Enduro are all that I've found.
    Jan 2015
    will the shimano xtr bb94 work? It says that it can accomodate the 92pf or... O forgot the exact size but i think its pf89? But im sure it accepts 24mm spindles like my slx crank.
    I would get something that has metal cups. I find the plastic ones are shit. Just my 0.02.
  1. Rip 9 RDO vs Evil The Following
    By Fastblack in forum Niner Bikes
    Last Post: 02-18-2016, 09:33 AM
  2. Anyone EVIL?
    By singletrack990 in forum Arizona
    Last Post: 10-30-2015, 05:57 PM
  3. Evil 27.5
    By bedell99 in forum Evil Bikes
    Last Post: 10-06-2015, 12:02 AM
  4. Evil D.O.C vs Evil Sovereign
    By woodc in forum All Mountain
    Last Post: 02-07-2011, 11:13 AM
