Creaky DELTA linkage on Insurgent?- Mtbr.com
Results 1 to 18 of 18
    Reputation: BossLog's Avatar
    Jan 2015
    Anyone else experience a stubborn creak? Removed all bolts and re-lubed and it just comes back. Appreciate any thoughts.
    I chased a creak on my Following, tried eveything from linkage to BB, seat, even the cables where they bend down and go into rear triangle. I spent a couple weeks hunting it down, turned out to be my hub, pulled that apart as last resort repacked it with grease. Bike is as quiet as can be now.
    Jan 2015
    Quote Originally Posted by simple78 View Post
    Interesting... This creak is definitely occurring with each compression of the rear shock. If I lock everything out its gone. So stubborn!
    i just chased down a creak by pulling the main pivot bearings, cleaning them, and re-installing w/ bearing prep and freshly greased threads on the bolt.
    Nov 2015
    Another possibility... I've been chasing down a similar creak / click and found out that it was my derailleur clutch. When the cage breaks free from a "static" position there is an audible click.
    BarBanger
    I too had a creak on my Insurgent. With almost every compression of the shock it would creak, or if i was out of the saddle climbing. I SWORE it was coming from the shock area. Turned out to be the upper headset bearing. Greased her up, now she's as quiet as church mouse.
    The massive downtube on the Evil bikes echoes like mad. I had a similar issue with my Following, but traced it to the lower headset bearing being filled with dust and grit.
    Jan 2015
    Thanks ya'll
    Sound like a few similar experiences. I'll check that headset.
    Sep 2014
    my new wreckoning is creaking way too much and i can't chase this down.....i have done a ton of greasing at this point but still have some spots to attack. i had an insurgent and it was silent but this bike is creaking/ticking from day one. i am kinda anal about creaks so this really bugs me.....any other ideas?
    BarBanger
    Seatpost? Headset? Fork crown? Shock bolts? Dirt had got between the cassette and the hub body on my Insurgent and caused horrible creaks. A little grease fixed that, too. Loosen your cranks and ride for a few yards. That can help isolate it to the cranks.
    Dec 2014
    had this issue on this morning ride....I've loosen the pivot bolt and the the sound was temporary gone, until i made few jumps then it came back.
    so gonna plan to take the main pivot bolt out n do an inspection then grease it thorougly amd will see how it goes.
    Reputation: titusquasi's Avatar
    Helpful thread as I'm preparing a Wreckoning build. I live in a dry and dusty area and have never had a bike that remained creak-free. I get tired of chasing them down so if it's not terribly obnoxious I just ride.
    I've also noticed that temperature differences can influence a creak. Warm days it may be gone, cold days it's back...and vice versa depending on the location.
    Feb 2016
    Check the built in chain guide, it can rub and squeak on the lower linkage hardware. If you loosen the bolt and slide it off the metal hardware (upward) that may fix the squeak.
    Dec 2014
    Quote Originally Posted by Spark91 View Post
    success, did not manage to get the grommet though but initial test ride, the creaks are gone, tomorrow will bring the Evil to the hills for ultimate test....
    SISSIF
    Reputation: TheCanary's Avatar
    May 2014
    Had more of a "Squeak" than a "Creak" with the Wrecker. Seemed to be from the main pivot that I had serviced trying to fix it. Checked with Evil to be sure I assembled the main bearing washer/seals correctly(I did) and they mentioned checking the chain guide:
    The inner rubber piece overlaps the main pivot head which rotates with suspension movement. Look for wear on the metal head. I had significant wear, took off the chain guide - Ahhh, quiet. They suggested a washer behind the rubber bit to help it stand off from the head. With the tight chain clearance on the guide to begin with, I decided to trim the inner guide like this:
    So far, so quiet.
    Big Wheels and Fat Skis keep me young.
    Dec 2015
    Had this same issue with a high pitch creak on my Wreckoning when the suspension was compressed. I dremeled off some material from the area where the chain guide was rubbing the pivot bolt. So far so good, hopefully that did the trick.
    Captain One Lung Administrator
    Reputation: JCWages's Avatar
    Jan 2015
    Quote Originally Posted by TheCanary View Post
    So far, so quiet.
    I have the same problem on my Calling. It was fine for a year and just recently started creaking. LBS figured it out and added a dab of grease to the pivot hardware. That lasted a week. I just took it apart and added more grease as well as adjusting the guide higher off the chainring. I figured I'd check the forum before I did any cutting. Thanks for the advice.
    With the inner rubber piece in place so you can see how tight the fit is.
    SISSIF
    May 2014
    Quote Originally Posted by JCWages View Post
    The trim fix is still quiet.
    Good Luck!
  1. Replies: 46
    Last Post: 06-09-2017, 01:24 PM
  2. Following vs Insurgent
    By Manolo Ibis in forum Evil Bikes
    Last Post: 03-27-2016, 06:47 PM
  3. Linkage Design: Evil Insurgent
    By Dude! in forum Evil Bikes
    Last Post: 12-13-2015, 11:24 AM
  4. Insurgent help
    By PUSHIND in forum Evil Bikes
    Last Post: 12-09-2015, 05:59 PM
  5. Creaky tracer 2 - linkage bolts?
    By huckgnar in forum Intense
    Last Post: 08-24-2013, 02:10 PM
Members who have read this thread: 17
