Small things that make a difference- Mtbr.com
    Aug 2005
    I had a decent year racing in the master class and would like to do better next season. I am pretty fit and have a pretty decent Downhill. I notice that on the higher speed and less techy, but still rough terrain, I am not as fast as others. I can usually win my class but when I do not its on the above mentioned sort of stage that I get beat.
    I am curious about things to work on over the winter and maybe some other fitness things to take into consideration.
    Thanks, Ryon
    If you do something often enough it tends to define you.
    Reputation: slimphatty's Avatar
    Try doing some xc races here and there. Do some specific interval workouts. High cadences always help. Be light on the pedals. Don't worry so much about going super fast. Just focus on being smooth. Concentrate on braking less, braking before the turn and releasing that brake lever throughout the turn, this will give you more exit speed. That's what you want. Look as far down the trail as possible. Hitting up the gym will work a bit too. Work out your core. Hope some of these help. Intervals always work but hurt.
    Reputation: 6280's Avatar
    Nov 2016
    My plan:
    Fat biking
    XC skiing and snowshoeing
    Gym
    Do a couple of XC races. Even making up numbers in the slow category is a good way to force yourself to push for a bit.
    Also spend some time at a pump track and practice making the most of the terrain to gain/maintain speed efficiently.
  1. Replies: 24
    Last Post: 09-16-2013, 02:30 PM
  2. What a difference small changes make
    By Fishermikel in forum Clydesdales/Tall Riders
    Last Post: 10-04-2012, 08:30 PM
  3. Replies: 12
    Last Post: 06-29-2008, 03:20 PM
  4. Small changes can make a big handling difference
    By mikepro in forum General Discussion
    Last Post: 10-23-2007, 04:45 AM
  5. Small things make a big difference..
    By wrtaylo in forum Turner
    Last Post: 11-19-2005, 03:19 PM
