Looking for Aluminum Enduro frame- Mtbr.com
Results 1 to 10 of 10
    May 2014
    New question here. Looking for Aluminum Enduro frame
    I am looking for a good aluminum frame for enduro(designed for180 mm fork preferred). I want something that would work well with CCDBCS inline. Any thoughts? I would like 650b an compatibility with a fox 36 float. If not possible I would be happy to go Rockshox. My order of importance is Aluminum frame-CCDBCS-650b-Fox. I will be building the bike custom. Any thoughts?
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Have you looked at Pivot firebird?
    Feb 2006
    Knolly Warden ticks all your boxes except fork length.
    beater
    Reputation: evasive's Avatar
    Feb 2005
    The Banshee Rune answers all those criteria.
    Reputation: KRob's Avatar
    Transition Patrol may be a good option as well. I really liked the shorter travel Scout I rode at Outerbike.
    Also look at the Guerrilla Gravity Megatrail. Don't know if it's 180 fork compatible but what fun, rock solid bike.
    If you can find a Knolly Chilcotin it would fit the bill as well. And it is 180 compatible (though "only" 26").
    Isaiah 58:14
    www.stuckinthespokes.com
    Reputation: batts65's Avatar
    Nov 2006
    Is there a 650b 180mm fork out there?
    Fox 36 is 160 or 170mm in 650b, does come in 180mm but only in 26 (unless there is something new out there).
    Any one of those mentioned above are good choices.
    I would also look at the Intense T275a
    Reputation: bridgestone14's Avatar
    Mar 2005
    You might be able to find a used tracer 2. I am pretty sure it will run a 180mm fork, not sure though . I have a 160 fox 36 on mine and it is awesome. Otherwise is meets the rest of your requirements. It will even take 27.5 wheels if you change the drop outs. Where do you need a 180mm fork for enduro?
    Looking for a Medium Scott Scale frame, preferably a 2012 in 26.
    Reputation: jlf.ski.bike.sail's Avatar
    Quote Originally Posted by Sf100al View Post
    ive got a 2014 banshee spitfire for sale. frame and shock are in mint condition no scuffs or scratches.
    2014 Spitfire Ano Black - Medium For Sale
    Ride fast. Take chances.
    www.stinride.com
    Jul 2014
    Megatrail - check out my review in the All Mountain section.
    Jul 2014
    Quote Originally Posted by colbatguano View Post
    To add to that, I haven't ridden anything on it that the 160mm Pike couldn't handle including some gnarly high-speed rock gardens and I weigh 245lbs with gear. So maybe a 180mm fork isn't needed?
  1. Specialized Enduro 29 aluminum weight???
    By mo6500 in forum 29er Bikes
    Last Post: 03-11-2013, 11:25 AM
  2. e160 on the 2010 Aluminum Enduro?
    By rangerbait in forum Specialized
    Last Post: 05-17-2012, 02:43 AM
  3. what is an 2011 aluminum enduro pro?
    By joyride153 in forum Specialized
    Last Post: 06-24-2011, 02:40 PM
  4. Frame weight: 2010 Enduro Expert (aluminum)
    By Dusty Bottoms in forum Specialized
    Last Post: 06-14-2011, 06:59 AM
  5. Carbon/Aluminum Enduro Frame Weights
    By The R in forum All Mountain
    Last Post: 06-10-2011, 03:09 PM
