Bottle Cage with Tool- Mtbr.com
Results 1 to 10 of 10
    enjoys skidding
    Reputation: jasevr4's Avatar
    Feb 2005
    Does anyone know of an alternative to the SWAT Zee Cage with tool?
    Are Specialized the only ones making them?
    Reputation: bryan_d's Avatar
    Duct tape?
    Kidding, I would like to know too.
    Just keep pedaling, don't stop pedaling.
    enjoys skidding
    Feb 2005
    FYI, I couldn't find anything comparable. I would have thought the "endurification" of the industry would have brought alternatives. I have a SWAT Cage in the mail.
    meow meow
    Reputation: b-kul's Avatar
    i think that i it. but the tool and case is removable from the cage, i broke it and replaced it with a standard metal cage fyi.
    Reputation: Mt. Tam Haze's Avatar
    Specialized is the only one make them now, i'm sure others will follow. Doesn't seem like a diversified enough tool to me though.
    There's always next year.
    Reputation: padrefan1982's Avatar
    Mar 2005
    The tool's perfect (in my view) for racing and short rides. Its not enough for backcountry rides, but I've needed to use mine 2 or 3 times, and it did everything I needed it too. Its not perfect (price...and no 8mm for my RF cranks being one of the issues) but its good piece of mind for me. Its very secure, so you won't lose it either. I'm a big fan of Specialized SWAT concept (love the bibs, and have the headset chain breaker as well)
    It is #enduro enough? I have no idea, but I've done 30 and 50 mile XC races with mine multiple times (with a strap on the saddle rails for tire and CO2) and always felt confident I had what I would need to limp to a aid station.
    It has an 8MM. The super flat bit is an 8 with the sides shaved off- try it out.
    Mar 2005
    So it does-- just went and checked in the garage. I don't know if I could get enough leverage to remove the RF bolt with the SWAT tool in the 'wild.' But good to know its there--if it got loose on a ride, it would be enough to tighten it up to get home I believe. The other multi-tool I carry in the bag has an 8mm, but isn't deep enough for the cranks.
    +1 rep to you, Steve
    Quote Originally Posted by b-kul View Post
    This is interesting. I''ve got a set of king ti cages (for life!)-- I use them because hard riding has broken carbon cages and ejected bottles from cheap plastic cages.
    If this swat item mounts up under any cage, securely, I'm in. Can you send a pic of your setup?
    meow meow
    Quote Originally Posted by rfxc View Post
    the tool portion just bolts under the cage on the bolt hole closest to the bb. not as snug as with the spec cage but no way it will go anywhere or even move.
  1. Replies: 10
    Last Post: 02-24-2014, 12:27 PM
  2. Jet 9 RDO Water Bottle Cage
    By tneker in forum Niner Bikes
    Last Post: 06-05-2013, 04:15 AM
  3. Bottle cage bosses
    By adarn in forum Frame Building
    Last Post: 07-25-2012, 12:51 PM
  4. Bottle Cage Mod
    By gbuckham in forum Fat bikes
    Last Post: 05-27-2012, 05:39 PM
  5. The Best Bottle Cage
    By ftajiri in forum 29er Bikes
    Last Post: 01-30-2011, 10:41 PM
