Results 1 to 7 of 7
    Reputation: poorboy006's Avatar
    To Pike or to Revelation...That is the ??
    Anyone have any experience with a Pike or a Revelation on their Ells?? I think the Pike might be a bit to much for my Distance. How does RS forks feel with the ATLAS rear end? Will that 20mm axel really have a profound effect on stiffness?
    Quote Originally Posted by poorboy006
    hello
    i've got a pike on my distance and a revelation on my ID.
    the pike match well with the distance, it make a great enduro bike: i live in france and the bike is perfect for riding in the alps.
    the maxxle is really stiff and really easy to use, it's a pleasure.
    the revelation is a lighter fork. it is a little shorter. more a marathon fork.
    it depend of the trail you are riding on and the way you enjoy your ride.
    Time is not a road.
    Reputation: chad1433's Avatar
    Seems like you got those forks backwards! The 5.5" Pike would match the Id better and the 5" Revelation would mate with the Distance perfectly, I would guess...???
    Really, 10mm isn't going to make much difference in the overall scheme of things. Getting a 20mm wheel was always the issue for me - more money, more costs.
    I think either would work out fine. I ran a Reba on my Isis and it matched the back end pretty good, 115mm front, 100mm rear. I settled on a Marathon up front at 120mm and I think this was a tad too much of a geometry change for the bike. At least with either RS, you can change the travel to match the rear if you don't like the way it's riding at any point.
    It's win-win! Pike air looks good...
    Quote Originally Posted by chad1433
    i put fork that way because ID pedal better than Distance and i prefer to use the distance on dh marathon in france.i also got a shorter rear shox on my ID and the revelation match well with that configuration. i try the pike on the id but the bike was unbalanced and i prefer it with the revelation (fork was too long).
    i've got a pike dual air and it is a really great fork. light,stiff,adjustable, smooth, great bottoming resistance.
    Time is not a road.
    Quote Originally Posted by dustplayer
    Makes sense to me!
    I use hope bulb hubs so the conversion is no biggy. If that 20mm isn't a noticable differance, than i think the Revelation's weight savings would be more important to me. Its just to bad that the Revelation dosn't come in silver. Thanks for the input.
    Time is not a road.
    The RS website notes that they come in Black, White, Silver and Mahogany. Though, it also stipulates:
    * Not all color and remote combinations will be available. See options guide or contact your salesperson for additional information
    Some guy had his Pike 454 on the shocks forum weighing in at just over 5lbs. Not too shabby, really for a long travel fork with a 20mm thru axle. Or, how about a Recon? There really doesn't seem to be much difference in the two models. You can opt for an aluminum steer tube and boss-less lowers. It'd probably save some cash, too.
