Results 1 to 3 of 3
Thread: Moment's weight
    Moment's weight
    In the E web site the following are the reported weight (lb.) for the Moment :
    15 in 8
    17 in 8.05
    19 in 8.45
    Do you know which shock ( DHX , RP3 ) are they measured with ? Basically I am trying to understand which is the frame only weight .
    Quote Originally Posted by alamak
    15 in 8
    17 in 8.05
    19 in 8.45
    I believe that was with a DHX Coil shock.
    My 2005 Moment in small weighs:
    6.09 lb. frame only - 15"
    1.0 lb. DHX Air with reducers attached
    0.11 lb. 2 pivot bolts
    7.2 lb. complete frame w/ shock
    The weight saving you get w/ DHX Air over the DHX Coil is about 12-13 ounces. The RP3 should be even lighter than the DHX Air.
    mda
    mda is offline
    My 05/06 Moment in medium weighs:
    Frame is 6.27lbs
    DHX coil shock body inc reducers and bolts is 1.06lbs
    500lbs x 2.35 steel spring is 0.85lbs
    Total frame plus shock is 8.18lbs
