Hey Id riders...- Mtbr.com
Results 1 to 6 of 6
    Something goes here...
    Reputation: Crash_FLMB's Avatar
    Hey Id riders...
    I've had my Id for about 9 months. Live in the NW where it's rain, rain, slosh, slosh on the trail. She's held up great and I haven't had to do any maintenance on her at all. On last nights ride, I discovered that where the shock attaches to the frame by the BB is a little loose. I think I just need to replace the bushings but I was curious if anyone else has had this problem? Could it be something else? I'm only 150-155 lbs (probably 160-165 with pack) so I know it's not a weight thing.
    I'm planning on taking her apart tonight to check but I'm almost positive it's just the bushing wearing out.
    Why would I need more than one gear?
    @A_SingleSpeeder
    I find myself enjoying gravel more and more lately...
    Since nobody replied, I guess I'm the only one who has had this problem. I was looking at the bike last night and discovered that the bottom bolt on the shock had come a little loose. So if anybody else has this problem, check that first.
    @A_SingleSpeeder
    Make sure your shock bolt is tight and not broken.....
    A broken bolt will rattle before pushing out the ends. If so, replace with stronger bolts from your hardware store and don't waste your time in a place like Lowes or Home Depot.
    Good Luck.
    Reputation: portnoy's Avatar
    the bolts occasionally loosen...
    ...check for that first. Make sure you use a torque wrench to tighten them to the proper torque. It has bearings, not bushings, which should last quite some time unless you've been riding it loose for awhile.
    Best,
    Michael
    Quote Originally Posted by Crash_FLMB
    I'll be along... eventually.
    Rolling
    Reputation: lidarman's Avatar
    Quote Originally Posted by msylvan
    Best,
    Michael
    Correction Michael, there are Aluminum bushings at the shock mount, not bearings.
    Could be just a loose bolt, tighten it and see if the slack goes away.
    One thing on FS bikes is, check bolts regularily. If a bolt loosens and you continue to ride it, you can really damage a bike. A loose bolt on a shock can shear the mounting hole on the frame or at least ovalize it. And I bet Mr T E will not warranty that kind of damage.
    True that... my bad...
    for some reason I was thinking swingarm bearings, not shock bushings. It's nice to be corrected or disagreed with on this board in a friendly fashion for once. Thanks man.
  1. Any Humboldt riders out there?
    By crawdad in forum California - Norcal
    Last Post: 02-11-2005, 08:00 AM
  2. Any Santa Barbara riders?
    By borg in forum California - Socal
    Last Post: 07-05-2004, 05:17 PM
  3. Pittsburgh riders
    By robinhood in forum Pennsylvania
    Last Post: 02-20-2004, 01:01 PM
  4. Kona Stab info - any riders out there?
    By freeriderB in forum Downhill - Freeride
    Last Post: 02-12-2004, 08:33 PM
  5. Replies: 0
    Last Post: 01-27-2004, 12:10 PM
