Results 1 to 3 of 3
    DHX 5 on a JOKER?
    I own a 05 JOKER, did any body try to put a DHX 5 coil shock on it?
    Jii
    Jii is online now
    Dec 2004
    I've seen pictures of a Joker with a DHX coil, but in that case the owner had machined an adapter in order to change the position of the shock, so that the piggyback would fit. The DHX doesn't fit as it is. The valve in the end of the piggyback hits the frame. I've been trying to get a hold of a DHX air with the correct i2i, so that I could try if it fits, since the valve is a lot shorter on that one. Official Ellsworth point of view is that neither fit.
    Thank's
