Results 1 to 11 of 11
    Mar 2005
    Anyone know how to calculate Epiphany specs?
    I'm trying to size an Epiphany but the Standover and BB heights are in code...anyone have the key?
    15 in 17 in 19 in
    Rider Height: <5'7" 5'5"-6'2" >5'9"
    Standover Height: +17.8 +17.9 +18.1
    Top Tube Length: 22.25 23.5 24.25
    Head Tube Length: 4.0 4.7 5 5
    Chainstay Length: 16.9 16.9 16.9
    Bottom Bracket Height: +.5 +.5 +.5
    Wheelbase: 42.6 43.9 44.7
    Seat Tube Angle: 73.5 73.5 73.5
    Head Tube Angle: 70 70 70
    Btm. Bracket Width(mm):73 73 73
    Seat Post Size(mm): 27.2 27.2 27.2
    Rear Travel: 5.25 in.
    Time is not a road.
    Reputation: chad1433's Avatar
    My "guess" is that you add 13", 1/2 of the wheel width to get the right info. But that, then, does not account for the width of a tire on the rim. Obviously, BB height and standover are "variables".
    Mar 2005
    I guess that makes sense
    Quote Originally Posted by chad1433
    if you apply those calculations to the specs of the other bikes and compare their looks, you get quite a difference in their geometry, though it must work, but that gives the epiphany a very high standover, especially the 15"
    Time is not a road.
    Paul might be able to better verify the specs. It seems that what was published in the catalog was very "raw" in order to get copy out before Interbike. Real world numbers are probably different.
    Maybe some of these folks with new frames can confirm.
    I think the bottom bracket height is 1/2" above the line drawn between the front and rear axles, it's a measurement i've seen other manuf. use and is not peculiar to Ells. Ofcourse that would depend on the tyres fitted.
    I can't see it being more than 13.5"- probably be less.Most people don't want a tall bottom bracket and they got some stick in the past for the Id.
    If i remember right my Moment was 13.5" when i had a Vanilla 130 fork on it with Conti vertical 2.3 tyres ( which run on the small side ) and it's not likely to be taller than that.
    Hope this helps although i can't be of any use with the standover measurement, but going off the photo's it looks like they've got it as low as they reasonably can so i wouldn't worry about either measurement personally- should be a great ride and if i hadn't just got a Blur LT ( which is just amazing BTW ) then i'd probably be looking at one too. Look forward to seeing some pics.
    You can't make a racehorse out of a donkey, but you can make a fast donkey.
    5 x 5
    Reputation: MrMountainHop's Avatar
    The key...
    Quote Originally Posted by JM01
    15 in 17 in 19 in
    From Ellsworth's 2006 catalog (lower right of same page as the specs):
    "All specs use the axel horizon line as reference
    when dealing with bottom bracket height and
    standover. (specs are (+/-) from this line.)"
    In other words, plus 13" for wheel plus whatever for your tires.
    e.g. a standover height on a 17" frame of 30.9" + tire height
    Hope that helps.
    "Check out dude."
    "Dude, crazy."
    Up & Down
    Reputation: El Sol's Avatar
    Sep 2004
    The Key is...
    Assuming your wheels, with tires, measure a true 26" diameter, take the radius(13") and add it to the BB rise. So, BB height for the Epiphany would be 13.5".
    If you're rolling fatties, your tire diameter may easily be greater than 26", which raises your BB a bit. I have a wheel set with semislick Kenda Klimax tires that measures 25.5" in dia, which would drop the BB to 13.25". The point being, wheel dia is a variable.
    Standover works the same. Add the tire radius to the standover number in the catalog. Standover in the catalog was measured 7"(175mm) horizontally forward from the BB center. That's more forward than Ellsworth measured Standover in the past.
    Hope that helps.
    Amphibious Technologies
    Reputation: SCUBAPRO's Avatar
    15 in 17 in 19 in
    Standover Height: 30.8 30.9 31.1
    Bottom Bracket Height: 13.5 13.5 13.5
    Rear Travel: 5"
    Standard Wheel + Tire radius ~ 13" (I don't know why they make it difficult ; just go with the standard. Everyone knows BB will vary slightly with different tire thicknesses but not by much)
    "The best you've ridden is the best you know" - Paul Thede, Race Tech
    Mar 2005
    Quote Originally Posted by SCUBAPRO
    15 in 17 in 19 in
    Rear Travel: 5"
    Thanks...that is one big bike, sad that Mrs. JM has such short legs...perhaps Ellsworth would consider a 13" version for the girls?
    Paper or plastic?
    Reputation: zorg's Avatar
    The standover seems all wrong. It seems that the standover on the Epiphany is taller than the Id, which does not seem right since the top tube slops more. Just my 2 cents.
    Faster is not always better, but it's always more fun
    Quote Originally Posted by zorg
    Ellsworth is creating some confusion with their use of the "horizon measurement" I guess they are trying to be technical about it and show the world they have some engineering background ("we must be accurate!!!"). They don't realize that the number they post will vary depending on the fork's A-C height too. Of course they took that into consideration; not!!!
    To make things worst, they won't even reply to posts like these. I've asked Mr. Psick about it on another post which he just ignored. So much for their great CS...
