Home bike mechanics - cautionary tale about 'Certified Multi-Purpose Degreaser' @CT- Mtbr.com
Results 1 to 3 of 3
    Reputation: Greg_o's Avatar
    Mar 2012
    Caution;  Merge;  Workers Ahead! Home bike mechanics - cautionary tale about 'Certified Multi-Purpose Degreaser' @CT
    Be very careful if you use this brand..
    For basic drive train cleaning I generally use Canadian Tires engine degreaser. Last time I went they didn't have any, but they did have the above product. (no idea if the CT brand is discontinued or if I just had bad luck that day and there was no stock.)
    I bought the Certified brand stuff, and while it does work well I realised it's a very different product - has a soapyness to it that if not thoroughly cleaned with water, it will attract tons of grime while riding. I also noticed that it just destroyed my hands form the little contact I had with it. (shouldn't be too surprised, it is labelled Corrosive..)
    Anyhow long story slightly shorter - I've had a persistent creaking sound coming from my chain rings. After a few attempts of disassembling and retorking the chain ring bolts that did not solve the problem, I realised I should probably be adding some grease between all contact points.
    Last night I dissamble, and figure I might as well clean the gears while I had them apart..
    Well this stuff is so strong it stripped the paint of my chain ring. It used to be solid black..
    Not playing the victim, this was my bad 100%, just wanted to warn others out there in case they are tempted to use this stuff on their bikes.
    ..now just tinker with our bikes and feed the cats. - oldbear52
    Well I guess if a person was looking for "paint stripper" they know what to look for.
    2008 Trek Fuel EX 8
    Apsley, Ontario, Canada
    Reputation: LyNx's Avatar
    If you do proper cleaning and maintenance on your drivetrain, you should never need any sort of crap like solvent, just hot soapy water, that's it. You learned a luckily not expensive lesson, be happy.
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
  1. Another Cautionary Tale
    By mtbxplorer in forum Commuting
    Last Post: 02-16-2016, 08:51 AM
  2. Sarma Vortex a cautionary tale
    By j_gantzer in forum Fat bikes
    Last Post: 02-13-2016, 07:54 PM
  3. Attempted Bike Theft: Aptos Cautionary Tale
    By bdamschen in forum California - Norcal
    Last Post: 04-07-2015, 12:30 PM
  4. Bad Tandem Shifting: A Cautionary Tale
    By Fleas in forum Tandem Mountain Bikes
    Last Post: 09-04-2013, 01:11 PM
  5. Cautionary Tale - Wound Care
    By Metamorphic in forum Rider Down, injuries and recovery
    Last Post: 11-28-2011, 08:13 PM
