Fox RP23 parts - local or mail order ?- Mtbr.com
Results 1 to 3 of 3
    db9
    db9 is offline
    Fox will not ship to Canada from the US, and I struggle to get parts ordered from my LBS and in a timely manner as well (yes I need a better shop)
    I'm looking for DU bushing reducer kit 803-03-143
    Suggestions?
    Drinkin' the 29er KoolAid
    Reputation: kwarwick's Avatar
    Yeah, I've found Fox parts difficult to get in Canada also. Are you replacing worn out bushings, or just need a set for a new build? If replacing because the originals wore out you might want to consider these: RWC SHOCK EYE NEEDLE BEARING KITS
    Although they like to sell you the bearings for both ends of the shock, generally you only need to install one on the end that sees the majority of the rotation. I've got them installed on two bikes and the lack of stiction is quite noticeable vs the stock aluminum reducers.
    Reputation: veteran_youth's Avatar
    Nov 2006
    Responded via PM.
  1. Mail Order Mistakes
    By junior1210 in forum Beginner's Corner
    Last Post: 09-22-2015, 04:38 PM
  2. dirt jump mtb mail order?
    By Jef O'blique in forum Urban/DJ/Park
    Last Post: 11-23-2013, 11:04 PM
  3. Mail order companies for new seat
    By mnormand in forum Beginner's Corner
    Last Post: 08-15-2011, 07:49 PM
  4. Pricepoint Mail Order
    By Atomik Carbon in forum General Discussion
    Last Post: 02-17-2011, 06:25 AM
