Disk Brake Adapter???- Mtbr.com
Results 1 to 2 of 2
    Does anybody know where I could get a disk brake adapter to allow putting disks on the rear of a 1999 GF HooKooEKoo?
    Kirk
    Crank monkey
    Reputation: Smytty's Avatar
    As long as your frame has tabs for a disk mount,
    you should be able to get one from your LBS. If they don't have one lying around, they'll order one up for you. They don't cost much, around $15, I think.
    If you don't have tabs, then you'll have to go with something aftermarket. Do a search in the braketime forum - I'm sure you'll find lots of info there.
    Cheers,
    Smytty
  1. disk brake adapters
    By boyfromthelak in forum Downhill - Freeride
    Last Post: 04-19-2004, 07:25 PM
  2. XT disk brake weight
    By TeXe in forum Weight Weenies
    Last Post: 04-06-2004, 06:55 AM
  3. New disk brake wheels help.....
    By TheSherpa in forum Weight Weenies
    Last Post: 02-26-2004, 02:59 PM
  4. Need disc brake adapter 74mm to 51mm
    By DIYguy in forum Brake Time
    Last Post: 01-26-2004, 10:15 AM
  5. Need disc brake adapter for manitou 74mm to 51mm
    By DIYguy in forum Shocks and Suspension
    Last Post: 01-18-2004, 08:05 PM
