XT I-spec II shifter with I-spec B brakes, solution.- Mtbr.com
Results 1 to 22 of 22
    I had a problem, I wanted new XT 11-speed shifters/derallieurs etc. but my bike had I-spec B XT brakes. Sure, I could have bought a bar mounted shifter with a ugly indicator or waited for the I-spec B XT 11-speed shifters. But since I am a little stupid I decided that there must be an easy way to solve this.
    In comes the Hope HBSP327R shifter mount for Hope brakes.
    This mount is designed to make the Tech3 lever compatible with I-spec II shifters. The Tech3 lever has a shifter mount that is I-spec A/B compatible. Thus the mount should fit a Shimano I-spec A/B lever and at the same time be compatible with I-spec II shifters.
    So I ordered a complete set of XT and the Hope HBSP327R.
    To my dissapointment the nuts and bolts that was supplied with the mount did not fit my I-spec B lever. (Should be plug and play for an I-spec A lever).
    But nothing is impossible! A little drilling, cutting and filing later a I-spec A nut I had was inserted in my I-spec B lever. The I-spec B nut was not usable. Mainly because the thread was not deep enough. The Hope mount was drilled to make the hole a little bigger. I just had to shorten the screw a little and put a washer underneath the screw and it all fitted perfectly.
    I-spec A nut
    I-spec A nut inserted in I-spec B lever
    From the inside with the little screw that holds the nut in place.
    The shifter attached to the lever
    If Hope could just supply my "special" nut with the mount it would be an easy way to adapt a I-spec A/B lever to I-spec II shifters.
    Thanks for posting this. I've been waiting for someone to hack a solution together for this.
    I think I'm just going to spend the extra $30 and go with the XTR bar mount shifter and leave my spec-b levers intact.
    Sent from my VS980 4G using Tapatalk
    B A N N E D
    Would it have been easier to attach with the I-Spec B bolt & nut unit?
    http://si.shimano.com/php/download.p...M780-3183A.pdf
    http://si.shimano.com/php/download.p...001-07-ENG.pdf
    Bolt & Nut Unit
    Part # Y6UV98090
    There is no thread in the bottom, just maybe 5mm at the end. So you can not just cut it down. However I did change to the I-spec B nut later but I cut it in half and drilled a new hole for the retaining screw. The material in the I-spec A nut was a little soft.
    Sep 2014
    Amazing, great work.
    In my case i have to match Shimano XT ispec A brakes and Shimano XTR 9000 ispec II shifters, do you think it's possible? If i understand correctly you believe that in my case i just have to use the supplied bolts and nuts that came with the hope lever clamp? I'm willing to give it a go .
    I had this brakes mounted with ispec B XT shifters so i know they are compatible with ispec B in any case
    I'm a doctor too
    Reputation: Pe8er's Avatar
    Dec 2015
    I'm in a similar situation: XT 8000 right shifter with indicator (SL-M8000) + Zee brake lever (BL-M640-B). Now, I figured out I would have to remove the indicator and the top cover entirely. I found an I-spec II cover unit available (Y03K98110) for $28. This would give me an I-spec II shifter and I-spec-B brake lever. Two questions:
    1. Would it work along with the Hope adapter? I know it sounds silly but I'm immensely confused by all these standards.
    2. Is this a fair price?
    Jan 2009
    Looks like the Ispec B shifters are starting to become in stock! Shimano XT SL-M8000-B I-Spec B shift lever right 11 speed (without optical gear display )
    Quote Originally Posted by John The rider View Post
    I think it will be easier with the I-Spec A brakes. Atleast in theory. But there is no guarantee. Only way of knowing for sure is to test.
    Quote Originally Posted by Pe8er View Post
    If the shifter is converted to I-spec II and your brake is I-spec B then the situation would be exactly as mine. But if you have an indicator, don't you also have the barclamp version? Seems easier to just fit it as it is then even though it is cleaner with shifter mounted to brake. About the price, only you can decide if it is fair for you
    May 2016
    Is there any way to do this if you have I-Spec II brakes and I-Spec B shifter?
    May 2013
    I have the older I-Spec-A Version of the XT 785 Brakes (pre 2014) and the Hope HBSP327R shifter mount for Hope brakes works just perfect! No modifications needed to attach the shifter mount to the brake, no other screws needed, too. Thank you for that great idea!
    Thatīs awesome, glad my fix helped someone else too
    Clean handlebars are nice.
    Aug 2016
    i'm pretty sure my solution is listed somewhere above, but it's all very confusing. I have the 2017 Ispec-II M8000 shifter and the 2016 Ispec-B M506 brake levers and they're not compatible. Is there either A) an after market adapter or B) a direct-to-handlebar mount for the shifter?
    May 2013
    Quote Originally Posted by beerdles View Post
    The solution is the first post in this thread.
    B A N N E D
    1) An aftermarket solution is what this thread shows
    2) The M8000 shifters come in 3 versions, a bar clamp version, a I-Spec II version and a I-Spec B version.
    3) You can change parts on your I-Spec II shifter to make it a bar clamp mount.
    http://si.shimano.com/#/en/EV/SL-M8000-3860
    https://www.sjscycles.co.uk/gear-spa...eft-y03l98040/
    https://www.sjscycles.co.uk/gear-spa...eft-y03l98070/
    https://www.sjscycles.co.uk/gear-spa...ght-y03k98050/
    https://www.sjscycles.co.uk/gear-spa...ght-y03k98080/
    4) You can change parts on your I-Spec II shifter to make it a I-Spec B mount.
    http://si.shimano.com/#/en/EV/SL-M8000-B-I-3948A
    https://www.sjscycles.co.uk/gear-spa...eft-y03l98130/
    https://www.sjscycles.co.uk/gear-spa...ght-y03k98140/
    Jul 2014
    Delete
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Just did this, got the hope adapter. Drilled it out so it would fit over the I-spec B bolt receptacle, then used a spacer on the other end and a brake-rotor bolt and it all fits together nicely.
    Jan 2009
    Chain Reaction has the I-Spec B shifter for pretty cheap.
    Giant Reign Advanced 1
    Reputation: ka81ua's Avatar
    Oct 2014
    Is there any news about brand product to match:
    Shimano brakes with i-spec b (saint m820) and Shimano right shifter 11sp XTR SL-M9000 i-spec ii ??
    OK
    Oct 2014
    Quote Originally Posted by Gilgo View Post
    I-spec A nut
    shimanos part number for that nut, please?..
    OK
    Apr 2018
    Quote Originally Posted by cobba View Post
    Manuals & Technical Documents
    Shimano says the main body is not interchangeable, so, I think is not so simple only changing the caps, like you propose.
    Reputation: NC Kingsting's Avatar
    Apr 2016
    For those of you looking to mount a XTR shifter (I-Spec 2) to a Saint brake (I-Spec B) problem solvers has a ready made solution. https://problemsolversbike.com/produ...match_adapters
    You want the rematch 1.2 left side which is part # BR7003. Price from my LBS before any discounts was $25.
    Jan 2017
    Hi everyone.
    I wonder if this hack would work on my Hope Tech3 levers.
    I've tried direct-mounting my Saint shifter to Hope lever, but due to significantly longer brake lever (compared to Shimano), shifter pads were impossible to reach without moving hand on the grip.
    The only option here was a KCNC XTR adapter, which was pain in the ass to install, as dremel and a washer were required for more-or-less proper fit:
    Now I'm planning to upgrade to XTR m9100, which, as internet says, is virtually the same design as previous I-Spec II shifters.
    I wonder if it will be same lever position with m9100 using Hope or Rematch 1.2 adaptors, as it was with direct-mounting my Saint shifter.
    Unfortunately, I have no photos of my Saint shifter attached directly to Hope brake, but you get the idea - shifter pads were ~25mm too short for comfortable use.
    It sounds like my best option to get bar-clamped shifter and be done with it, but I want to try-out ESI or Lizard Skins DSP grips, which would render removing of shifter impossible without cutting your right grip.
    Is there anyone with similar problem as me?
    Any advice is appreciated.
    Thanks.
  1. How can I make Shimano XT I-Spec B shifter work with a non-I-Spec brake lever?
    By cat5fred in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-20-2015, 12:37 PM
  2. XT Brakes + I-Spec Shifter Mounting Nut
    By ledrefoc in forum Brake Time
    Last Post: 06-26-2014, 01:08 PM
  3. Shimano i-spec mashup (i-spec B brakes with i-spec a shifters)
    By FM in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2014, 09:40 AM
  4. how to use I-Spec with Zee shifter + brakes?
    By dfuse in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-02-2013, 12:12 PM
  5. i-spec? xtr shifter with xt brakes
    By dutchct in forum Shimano
    Last Post: 09-19-2012, 05:46 AM
Members who have read this thread: 18
