X01 crank torque?- Mtbr.com
Results 1 to 7 of 7
    Jun 2013
    X01 crank torque?
    I bought an Absolute Black oval direct drive chain ring to replace the stock eagle 30T. Not having done work on cranksets before I found this video https://www.youtube.com/watch?v=VUoPXxEn93g . The mech uses a 8mm hex and without a great deal of effort loosens the bolt (maybe it was pre-released). When I went to do it I couldn't break the bolt loose until I got someone else to put their maximum strength/weight bracing the pedals/crank while I cranked on it with a 8mm hex pedal wrench. I finally broke loose under max effort by both of us.
    Do cranks tighten up with use or was this one over torqued? I found spec's at 54 Nm (478 in-lbs), but will need to get my large torque wrench back from my son before known values.
    Reputation: J.B. Weld's Avatar
    54 Nm is really tight, unless they're under-torqued they're always hard to loosen.
    I brake for stinkbugs
    Reputation: bcriverjunky's Avatar
    Jul 2014
    Specs are printed on the crank bolt cap.
    Bucksaw, Farley, and a Sturgis....
    Trail Rider
    Reputation: mlx john's Avatar
    48-54nm
    2020 SC CC Hightower
    Reputation: Lone Rager's Avatar
    Dec 2013
    Def go with the spec. Grease the threads and splines first.
    Do the math.
    Jun 2013
    Thanks all
    since 4/10/2009
    Reputation: Harold's Avatar
    It was probably pre-loosened for the demo video.
  1. Comparing stiffness of SRAM cranks - X1/X01/XX1 and Eagle X01/XX1?
    By morkys in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-18-2017, 05:37 PM
  2. Nomad 4 X01 vs Hightower LT X01?
    By spikebike in forum Santa Cruz
    Last Post: 07-10-2017, 11:38 PM
  3. SRAM X01 Eagle Crank Torque
    By zepplin758 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-03-2017, 03:49 PM
  4. SRAM X01 or X01 GXP Crank Arms - 170MM, 168 Q Factor
    By Averbuks in forum Where are the Best Deals?
    Last Post: 06-15-2016, 07:20 PM
  5. X01 cranks OEM [Alloy] Vs X01 cranks aftermarket [Carbon]
    By jeffgre_6163 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-06-2014, 11:29 PM
Members who have read this thread: 24
