Results 1 to 6 of 6
    Apr 2015
    Where do I find plastic tubing to run internal cables?
    For the life of me, I can't find the little plastic tubing I see people using in videos when replacing internally routed gear cables. It looks like it's fairly stiff, obviously hollow and somewhere around maybe 1/8 inch od.
    Where can I find this stuff, and what is it originally made for?
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Usually you use regular full length housing, what are you trying to achieve with plastic tubing?
    This tubing is hard to find "retail" but my LBS was able to order it from their "big book of bike supplies/parts". So talk to your LBS.
    The alternative is to cut down the center of regular gear outer cable, pull away the metal rods and extract the thin inner sheath. Don't use really old, used cable as it tends to be worn through in parts.
    Apr 2015
    Quote Originally Posted by dischucker View Post
    Thank you!
    Reputation: watts888's Avatar
    Oct 2012
    not familiar with internal routed cable, but from the above discussion, it sounds like it has a smaller outside diameter than normal gear cable? If it ihas the same teflon inner with linear strands as normal gear cable but with a thinner protective shield, I'm surprised jagwire doesn't offer something off the shelf.
    "a hundred travel books isn't worth one real trip"
    Jagwire MTB cable kits come with what they call "sealing liner" - a plastic tubing that can cover the cable.
    Mountain Pro Shift | Jagwire
  1. Internal Cables
    By Slabysz in forum Frame Building
    Last Post: 10-10-2014, 10:26 PM
  2. Blank covers for internal cables
    By gulljammer in forum 29er Components
    Last Post: 04-10-2014, 03:42 AM
  3. How do you lube internal routed cables?
    By atayl0r in forum Tooltime
    Last Post: 03-26-2014, 11:14 AM
  4. Running internal Gore Ride On cables
    By rockyuphill in forum Rocky Mountain
    Last Post: 11-04-2013, 11:31 AM
  5. How do I Criss-Cross parrallel cables on internal routing?
    By roobydoo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-07-2013, 10:35 PM
