Results 1 to 3 of 3
    Dec 2013
    Where to buy shims, and limit screws for Shimano Atlus FD 310?
    http://www.shimano.com/media/techdoc...9830713900.pdf
    Y5GZ98010
    Clamp Band Adapters for S-size /
    φ
    28.6 mm (1-1/8") B-Type
    Y5L298010
    φ
    28.6 mm (1-1/8") A-Type
    Y5KJ98010
    Stroke Adjust Screws (M4 x 12) & Plate
    Dec 2013
    Well, I thought I could buy these parts from Shimano, but I couldnt find anything even at Niagara and Chain Reaction. I went ahead and cut a 3/4 pipe with a flared end, then split it length wise to go from 34.9mm to 28.6mm, works perfectly. Tire inner tubes dont work, there is too much play. It needs to be rigid.
    Secondly, I went to home depot, bought some M4 bolts, but the heads are too big. I found a local fasteners store that sells M4 socket style, which will be better because then the heads wont become worn out like they did with a star (philips???) screwdriver.
    Reputation: J.B. Weld's Avatar
    Some bike shops have bins of scraped derailleurs they use for parts, it wouldn't hurt to ask. If you have a bike coop in your area you're definitely in luck, they'll have buckets full of them!
  1. Limit Screws Need Replacing
    By matt4x4 in forum All Mountain
    Last Post: 07-15-2014, 02:07 PM
  2. Front derailleur limit screws, no effect
    By Kimv in forum Beginner's Corner
    Last Post: 06-17-2014, 05:15 PM
  3. Some pointers on adjusting Shimano XT Shadow rear mech screws
    By Andrewfuzzy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-22-2013, 01:07 PM
  4. Shimano Ice Tech Rotor Shims
    By dulyebr in forum Brake Time
    Last Post: 05-18-2012, 07:50 PM
  5. 32t chainring for Shimano Atlus crank?
    By onlyoyster99 in forum Singlespeed
    Last Post: 08-09-2011, 11:22 PM
