What are your gears front & back?- Mtbr.com
Results 1 to 40 of 40
    Jan 2013
    Just a general discussion…
    I've always thought the number of chainrings, rear cogs and number of teeth portray the type and level of rider.
    Personally, I can't go without three chainrings ideally 44/32/22 in the front. And 5 to 9 speeds in the back is good enough for me. Ideal range is 11-36, but I'm getting the Mamba that has 11-34.
    How the heck do you get by with fewer gears?
    Over the Hill
    Reputation: dstepper's Avatar
    20x30 front 11x38 back on niner wheels.
    32x20 on the single speed also niner wheels
    20x32 front 11x34 on the freeride bike 26 inch wheels
    32 and alfine on the bike packing bike niner wheels.
    You get by with fewer gears by building a light single speed bike then ride the **** out of it.
    Dean
    Gears... I hate gears
    Another single speeder here. 32x20 on a 29er. It was not my original plan to go single speed. First I wanted to convert to a 1x7 setup by just taking off the front derailleur and the excess chainrings but I kept dropping the chain. I have not regretted a single moment.
    I'm running 28t up front and 11-36 in the rear with 29in wheels.
    Reputation: breckenridge's Avatar
    Just made the switch from 22-32-42 x 11-34 3x9 to 27-40 x 11-34 2x9 on my 29er. Gear ratio coverage is pretty complete less a little bit on either end, we'll see how it translates on the trail come spring.
    Reputation: Roadsters's Avatar
    I wish I could find a thread that lists how tall everybody in the world is. I'd just like to see where I fit in.
    TOP TIER LURKER
    Reputation: Hawgzilla's Avatar
    Nov 2008
    29er with 2X9: 38/26 & 11-32
    life is... "All About Bikes"...
    I like turtles
    Reputation: TiGeo's Avatar
    29er 1x10 w/33t front ring and 11-36 rear. Crank is 170. Perfect set-up for everything I ride. I used to ride a SS w/a 32x18 w/175 cranks, but started out in the SS world on a 32x20. To Roadster's request above, I am 5'6", 165, 40 yo. Opps...almost forgot my road bike! 39/53 with a 12-23 8-speed.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro AF
    Reputation: thecanoe's Avatar
    24/32/bash front x 11/36 rear on a Tallboy c.
    At my age you never have enough low gears.
    Santa Cruz Tallboy
    Moonlander
    Jan 2013
    Quote Originally Posted by breckenridge View Post
    Interesting charts.
    Not sure where everybody else rides, but here in the SF Bay Area there are a lot of steep technical hills. And depending on season and recent weather, they could be soft, rocky, loose, avalanche ready, etc.
    So how the heck do you climb them without at least 22 front + 34 rear?
    I know I know. Skill and awesome leg strength. Right?
    Jan 2013
    Quote Originally Posted by Roadsters View Post
    That's easy, you silly little buzzkill. Just post a question, "how tall are you?" and wait for replies. See who's interested. Or just Google "average human height."
    Jan 2013
    Quote Originally Posted by thecanoe View Post
    Same sentiment here. Maybe my age is showing.
    TOP TIER LURKER
    Nov 2008
    Quote Originally Posted by solidass View Post
    If you change your gearing to something harder to push, you end up adapting in a short time. It also ends up making you stronger. It also gets you to the top of that steep mountain a bit faster. People begin to accuse you of having a motor or jet packs attached to your bike,...
    Out spokin'
    Dec 1999
    29er SS = 30f x 19r
    69er SS = 34f x 20r
    29er FS = 22+30f x 11-36r
    =S
    disciplesofdirt.org
    Dec 2012
    29er
    1x9 - 32t, 12-36 cassette
    Dec 2012
    Interesting charts.
    Try and use momentum to your advantage. Change lines, paths, streets, etc. I found that I was just as tired going up hills in 22t/34t as I am using 32t/36t. Then I realized I was sitting on my ass, not using the previous downhill to my advantage, and well...generally being a ***** lol. San Fran is full of singlespeeders.....you should be able to do it without a 22t.
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    Quote Originally Posted by reedfe View Post
    I had that problem until I got a chainguide. I use the mrp one, but any would probably work.
    Rod
    Rod is offline
    Oct 2007
    I have a couple of options that I like.
    29er 32 front 1x9 rear 34 large cog. I can use this gearing for anything I want to climb in Appalachia and this is my racing setup.
    Singlespeed I have two cogs. When climbing I go with a 32 front 19 rear and I use this for the climbing trails 1,200 vertical feet in a mile and the flatter trails I go with a 32x16. When I use the 32x16 I have to ride with some faster people or I will be ahead of everyone because you have to keep your momentum with that gearing.
    Jan 2013
    Quote Originally Posted by Rod View Post
    ... When I use the 32x16 I have to ride with some faster people or I will be ahead of everyone because you have to keep your momentum with that gearing.
    You guys on fewer cogs or single speed are pretty awesome. Seriously. I'm too old to develop that kind of leg power.
    The technical climbs in my local trails are long. Momentum can only help at the beginning ascent. Sometimes the top is the steepest part. Even when the trails get busy and powerful young guys just stampede through, I notice every one of them just walk the last five yards. They do it so quickly that it doesn't matter. Still lightning quick passage. They're gone in a blink.
    I can only imagine top tier racers completely charging all the way through on every trail.
    Feb 2006
    Currently 1x10 with a 32 up front and 11-36 rear. When the spring comes and the technical trails open again we'll see if I can hack it, if not I'll add a 24 up front and use it for the couple of lowest gears. 32-36 seems pretty easy to spin so maybe I'll be able to manage the 1x10.
    I'm 40 and my knees hurt, but I like the idea of 1x10 so I'm going to try to make it work.
    Jan 2011
    SS 29er- 34 x 18
    Geared 29er- 40/28 front, 11-36 cassette
    Road- 53/39 front, 11-25 cassette
    One Gear
    Reputation: .40AET's Avatar
    32/19 on a 29er. Is more better???
    I like turtles
    Quote Originally Posted by L. Ron Hoover View Post
    Its much like riding a SS; you just need to put in some time and your strength will increase so that it isn't as hard. A 32x36 is a pretty good climbing gear unless its just miles of super steep stuff.
    Out spokin'
    Dec 1999
    Maybe not, my friend. How young are you, solidass? And what's the terrain like where you live?
    I'll be 60 on my next birthday. Most elevation I've gained in a day on a bike is ~17,000' but the last time I did that (2011) was with gears. Haven't gained that much in a day on an SS since '02... I was only 49 y/o back then.
    Maybe you're older, I don't know. Or maybe your terrain is way technical / steep. Personally I live about a half hour from Oakridge, OR, in the Cascades "foothills." Foothills in quotes because we're talking about trails as high as 7,000' elevation.
    Anyway my point is this...
    You can do it.
    If you want to.
    --sParty
    disciplesofdirt.org
    May 2012
    Geared 26: 38/28 front 12-28 back (2x10)
    Takes me everywhere
    I am hoping my 27x34 is all I'll need around here. I never frequently used the 22x32-34 gears unless I was just dead tired, most climbs around here are slow and gradual or steep and short, since there isn't that much elevation to change in one climb. The local ski resorts only have about 700' total elevation change. We will see though, I hope its enough!
    Dec 2010
    1x9, 26" 32 front, 11-34 back.
    Go with what you're comfortable with for the terrain you have in your neck of the woods. IMO, it's much preferable to ride up anything (even slowly) than to walk up it.
    Reputation: roaringboy's Avatar
    2x9 is 28/40 front, 11/32 rear.
    SS is 32 front, 16 rear (i think).
    Both 26" wheels.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    All 29er's
    3 x 9 38 32 20 with a 12-34 cassette
    3 x 9 44 32 22 with a 11-34 cassette
    Single speed 34 x 16 running 8-speed chain at present that can morph in to 32 16,17,18,19,20
    I've ridden 2x10 four times (all on high-end bikes! Ibis, Turner, Pivot and Santa Cruz) 3 of the 4 times the chain dropped or sucked like a hoover vacuum. I'ma stick with 9-speed and have better chain durability, less finicky shifting BS, reusable quick links (without vise grips, channel locks...), lower cost...
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Currently:
    29er HT (race bike): 28/42 x 11-36 in upstate NY / Fort Collins, CO.
    Future:
    Same 29er HT, 36t x 10-42
    Santa Cruz Blur LT Carbon 36t x 11-36
    Death from Below.
    Reputation: rupps5's Avatar
    26er geared hardtail 8sp 12-32 with 26-40 front
    26er geared am bike 8sp 12-32 with 22-36 front
    26er single speed am hardtail 18 32
    29er hardtail 9sp 12-32 with 22-32-44
    1x9 on 29er front 34 rotor q ring, back 11-34
    2x10 on 29er front 33/23 rotor q rings back 11-36
    29er with rohloff speedhub 41 front 17 rear
    26er with rohloff speedhub 42 front 16 rear
    26er 9 speed 22-32-42 front 11-34 rear
    29er 10 speed 24-38 front 11-36 rear
    What? There's more?
    Reputation: tyrebyter's Avatar
    Started with 3X9 22-32-44 x 11-32... the big ring was just a leg-muncher in crashes, so 22-32-bash x 11-34... oops, front derailleur won't fit this frame... 32 x 11-34... These old legs will never push that up hill.... turns out they will if there's no granny option. Who knew?
    Reputation: TwoHeadsBrewing's Avatar
    Last year I moved from a standard 3x9 setup, to a 2x9 24/36T/Bash crank setup (same cassette), and that was a killer for the first few rides on the really steep stuff. I lost the equivalent of 1 1/2 gears, but thankfully there really aren't any "unrideable" steep sections...just have to stand up and grind it out rather than spin.
    But most recently I've moved to a Shimano 2x10 setup, and got nearly all of my range back compared to the 3x9. The crank is a 26/38T and the cassette is an 11-36T, so the lowest granny gear is perfect for those steep grinds. I lost a couple gears on the top end, so I spin out faster on the gravel roads at over 20mph, but I never run out of gears on actual trails.
    By the way, I made a gear ratio spreadsheet which makes it easy to compare different gear combinations with your current setup:
    https://docs.google.com/spreadsheet/...mc&usp=sharing
    "Got everything you need?"
    Jan 2013
    Quote Originally Posted by TwoHeadsBrewing View Post
    Excellent spreadsheet! Thank you for posting!
    I must confess that "moving up" to the stronger intermediate setup with just two front gears (the absence of the granny option as mentioned ) is my struggle. So while I want to build up strength and endurance again to do it — to not need the granny option — occasional seasons off and advancing age kill my chances.
    So I need my granny option!
    Reputation: uzurpator's Avatar
    Dec 2005
    enduro/fr 26" fully - 35/21 front and 12-30 rear
    xc 26" fully - 38 front, 11-36 rear
    commuter/road 700c - 39/26 front, 11-25 rear
    Class Clown
    Reputation: dundundata's Avatar
    hardtail 26
    11-32, 22-32-44
    May 2010
    Hardtail 26
    11-34,32-22
    dru
    dru is offline
    29er 30x20 Alfine
    26er 34/24x13-34 modified cassette.
    Yes, they easily spin out on the road.
    Drew
    occasional cyclist
