What is this ticking?- Mtbr.com
Results 1 to 8 of 8
    Caution;  Merge;  Workers Ahead! What is this ticking?
    For the last couple days now whenever I pedal there is a ticking noise coming from the crank it seems, does anyone know what this is and how I could stop it? Also I would like to know how to take it off because I would like to clean it.
    Thanks in advance, Greg
    Reputation: palerider's Avatar
    I had same problem
    I tighted my chainring bolts and it went away. Also try removing cranks and retighting the bottom bracket, that should fix it 98% of the time.
    Quote Originally Posted by GerGa00
    loose crank bolt, loose bottom bracket, loose chainring bolt, loose pedal, bad pedal bearing, bad bottom bracket bearing, cracked bottom bracket shell, ect.... the list is pretty much infinite.
    <a href="http://www.parktool.com/repair_help/tool.shtml">Parktools</a> has is pretty good site for repair instructions.
    How do i take the crank off? I tried it before but it wont come off after take the screws out.
    spotlust
    Guest
    depends on what crankset you have.
    In the link on my post is CPP-2 and CPP-4. Figure out which one you have and use the appropriate tool
    MTB Rider
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    Tools ...
    Quote Originally Posted by Ratt
    This one does splined and square taper
    http://www.pedros.com/frames/tools.html
    If you don't have many tools, and you want to save a buck, Pricepoint has a cheapo $40 toolkit that has pretty much everything you need in it. It's not high quality, but it's enough to get you started.
    http://www.pricepoint.com/detail/119...ntool-Kit-.htm
    The kit has a universal crank puller, a crank bolt wrench, etc... It does NOT have a ring nut wrench.
    make sure the crank isn't tapping the left over front derailluer cable.
  1. Ticking Drivetrain...Help!
    By pico199 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2005, 05:56 PM
  2. ticking into clunking or why...
    By ArmySlowRdr in forum General Discussion
    Last Post: 03-20-2005, 02:10 PM
  3. Manitou Black Elite Ticking Problem?
    By sfr4dr in forum Shocks and Suspension
    Last Post: 02-04-2005, 01:38 PM
  4. Creaking, ticking, rear hub bent... *Very* depressing
    By martinman in forum Clydesdales/Tall Riders
    Last Post: 08-14-2004, 07:45 PM
  5. Times ticking away (pedal ?)
    By crux in forum Riding Passion
    Last Post: 04-01-2004, 09:01 AM
