Results 1 to 7 of 7
    Oct 2018
    What derailleur do I need?
    I have a new 11-40 10s cassette. But my old slx derailleur is not good for it.
    Do I need to buy a new derailleur? And which one do I need?
    Someone told me I can buy slx 11s derailleur and it will work for 10s. Is it right?
    And do I need sgs or gs?
    Please help...
    Jul 2017
    The new generation 10spd derailleurs (m6000 deore and m7000 slx) will work.
    Or, like what you were advised, an 11spd derailleur eill work as well. Might be a better option if you decide to go 11spd in future.
    Reputation: LyNx's Avatar
    What is "old", is it a 8 or 9 spd or 10 spd? If it's anything before 10spd, then getting it to work would be more trouble than it's worth, even if you can, if it's a 10spd, all you might need is a longer B_Tension screw or Wolf Tooth GOAT LINK. If you just want a new derailleur, then yes, an 11spd Shimano will work with 10spd shifters for future compatibility in case you move to 11spd.
    If it's only going to a 40t cog, then a medium cage (that's GS) will work fine, but you can use a long cage (SGS) if you want, just a bit closer to the ground and obstacles, but you will have the ability should you choose, to go to a bigger cog next time you replace your cassette. CRC has the 10spd SLX M7000 on sale for $42 US.
    Quote Originally Posted by Netan View Post
    Please help...
    Oct 2018
    It is 10s slx derailleur. So all I need is to find a longer b screw? I really don't want to spend a lot of money so it's not like I'm looking for excuses to buy a new derailleur.
    Basically, most times, yes, a longer B-Screw should do the trick to get it to work with a 40t, but depends on which version you have, the older non-clutch or newer clutch style. If the longer B-Tension screw doesn't work, then a WT Goat Link is about $20.
    Did you crank your B screw as far in as possible to see how close it would get to working? Is it trying to get on the 40T at all? Reversing the B screw could work and give you that extra bit if reach to see if it'll work.
    Oct 2018
    I got the derailleur with the clutch system.
    I already got it to go on the 40t cog but then it won't reach the 11t cog.
    And after some tuning I got it to reach a cogs but no matter what I'll do it will never turn smoothly. If I try to adjust the derailleur either way it will stop reaching the 11t or 40t cogs.
    I'm running an 11spd XT rear derail on my 10 spd setup. Worked great until I tagged a rock. Strange enough I did not even have to adjust it for my 42T cog. Just mount & go! I'd replace the cable also just because they are cheap. Save the old one for the parts box for a trail side fix.
  1. Bent Derailleur or Derailleur hanger? PICTURES
    By Jayrock205 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2015, 11:35 AM
  2. Replies: 10
    Last Post: 10-16-2013, 06:17 PM
  3. Replies: 0
    Last Post: 03-28-2013, 04:05 AM
  4. Need help with new crankset; need a new front derailleur?
    By enyceckk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2011, 02:53 AM
Members who have read this thread: 46
© Copyright 2018 VerticalScope Inc. All rights reserved.
