what is acceptable min clerance between chainstay and inner crankarm?- Mtbr.com
Results 1 to 12 of 12
    Hack Racer
    Reputation: Cheers!'s Avatar
    Guys,
    Question. What is the min acceptable clearance between the chainstay to inner crankarm?
    XTR FC-M985 has measurement from centre of BB to inside of pedal arm to be 66.0mm.
    My lynskey M230 frame has a width at that location of 125mm. If I divide by 2, that is 62.5mm
    That would give me only 3.5mm... Is that way too close? Will the Ti frame flex enough under cornering that while I pedal the crank arm will make contact with the pedal arm?
    Thoughts?
    Reputation: elcaro1101's Avatar
    I think the BB shell width is what you need to measure, then use this document to decide what spacers you need to use based on the width and FD type.
    http://techdocs.shimano.com/media/te...9830726445.PDF
    All installed correctly, I think its safe to assume Lynsky made sure it will work. If your too heavy though, then all bets are off. I have no problems with my ti frame and Im not a small guy, but it isnt a Lynsky .
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Cheers! View Post
    Guys,
    Thoughts?
    0.001mm
    If the ring does not rub in use, it is fine.
    mtbtires.com
    Hack Racer
    So there is no chance the frame will flex enough under cornering loads to cause the chanstay to make contact with the crankarm?
    Seeing how the Shiggy has spoken I will take your word on it.
    LightJunction.com
    Reputation: lightjunction's Avatar
    I'm not aware of one. There should be enough clearance that when you're pedaling, even under stress, the arm doesn't hit the chainstay. Other than that, you should be fine.
    We sell quality bike headlights and flashlights.
    www.LightJunction.com
    Feb 2010
    I would like to follow up on this a little. I am installing a Midleburn duo(isis) on my bmc fs 01. When I had this installed on my Superlight I was using a 108mm bb to get a good chainline to run big/big. With the elevated chainstays had no clearance issues with crankarms. On the bmc clearance is minimal, like 1-2mm. No issue with chainrings. I am very leary of the arms being that close to the carbon stays as I am cranking those babies around. Should I be worried or give it a try.
    Reputation: G-Choro's Avatar
    i just installed the XTR 985 race cranks as well. rings have no problem, but my drive side crank clears the chainstay by 1.5 to 2mm at most. the NON-drive side has at least twice that clearance. what is more of a concern to me than clearance is the fact that the cranks don't appear to be centered in relation to the center line of the frame.
    Dec 1998
    Please note I said "in use." Amount of flex in a bike varies.
    IME 3.5mm is HUGE clearance.
    mtbtires.com
    Hack Racer
    How much clearance should be the minimum for between the big chain and the chainstay?
    Dec 1998
    If it does not rub in use, a miss is good as a mile.
    mtbtires.com
    Hack Racer
    I realize this too. But buying an expensive crankset and it not working becomes an expensive experiment.
    Hack Racer
