Results 1 to 13 of 13
    Calm like a Bomb
    Reputation: stunzeed's Avatar
    Trouble Removing Race Face AEfect cinch cranks
    I removed the crank bolt and tried banging on the drive side arm to get it out but it won't budge. Do I just need to use more force or am I missing something?
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by stunzeed View Post
    cinch system uses self-extracting crank bolt. it is 8mm. loosen it and the crank comes off. but it requires the 16mm cap to be installed first. If you removed it, then the 8mm will back out, but not pull the crank arm off.
    With that said, reading up on the new AEffect cranks, they only use the CINCH interchangeable spider. NOT the whole CINCH system (which includes the spindle). RaceFace's website says these cranks use their EXI spindle interface.
    Looking at the install instructions
    http://www.raceface.com/comp/inst/B1...lation-Web.pdf
    If looks like this EXI system would require the use of a crank puller to remove.
    http://forums.mtbr.com/drivetrain-sh...ks-960263.html
    Looks like specifically, you need an ISIS compatible crank puller.
    612 is offline
    Oct 2015
    I believe you need a shimano octalink or FSA isis drive style crank puller. Run to the lbs and they'll have it
    Ride Everything
    Reputation: GRAVELBIKE's Avatar
    Just looked at the Aeffect cranks that came on my 2016 Transition, and there's definitely no self-extracting cap. Looks like it's time to order an extractor...
    GRAVELBIKE.COM - ride everything
    Oct 2015
    Oct 2015
    loosen the nut and go for a ride and wait for the snap...thats how i get rusted rims off the car ;-)
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    Glad I found this thread... for the life of me, no amount of swearing and rubber mallet were enough to get the Aeffect crank arm off.... Now I realize I need a puller.
    Santa Cruz Hightower LT
    Jul 2018
    Once installed my aeffect crank is not spinning freely. Any suggestions?
    since 4/10/2009
    Quote Originally Posted by srkoellmer View Post
    Too many spacers
    Sent from my VS995 using Tapatalk
    LCW
    LCW is offline
    Possibly overtightened. Did you torque to spec via a torque wrench?
    Jul 2018
    Quote Originally Posted by LCW View Post
    I suspect I overtightened it. Buying torque wrench now
    Reputation: bluebomberx's Avatar
    You likely put the drive side bushing in backwards before torquing it.
    Nutrailer
    Reputation: JackWare's Avatar
    Aug 2016
    The Raceface instructions are here for the Aeffect Cinch crank;
    http://www.raceface.com/media/B10187...lation-Web.pdf
    What a perfect waste of time
  1. Race Face Cinch BSA 30mm BB Alternatives?
    By l3eaudacious in forum Fat bikes
    Last Post: 12-22-2017, 07:45 PM
  2. Race Face Turbine Cinch 1x crank
    By LeeL in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-06-2017, 04:34 PM
  3. race face cinch vs sram xo
    By blkcheerio in forum Beginner's Corner
    Last Post: 06-28-2015, 10:16 AM
  4. Race Face Cinch vs. SRAM XO1
    By LaCostaClydesdale in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-30-2015, 09:19 AM
  5. Removing Race Face Evolve Cranks
    By higgs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-21-2015, 08:50 PM
Members who have read this thread: 45
