Results 1 to 2 of 2
    Aug 2013
    Trek Top Fuel 8 chain ring swapout
    I am thinking of buying a topfuel 8 with the Shimano double chain ring.
    I have done the calculations on the gearing and I am confused as to why they have made the lower gears so low in comparison to the 1x11 on the topfuel 9.
    Gearing
    My hard tail 10x3 High 3.82 Low .67
    TopFuel 8 10x2 High 3.27 Low .61
    TopFuel 9 11x1 High 3.2 Low .76
    I only ever get as low as 2nd which is .75 but I use my top 3 gears a fair bit. With my style of riding I would prefer to have taller gears so question
    Considering this bike has the Boost rear hub fitted will any of the larger sets of chain rings 38/24 or 40/28 fit the shimano M627 crank?
    May 2015
    Is your hardtail by chance a 26" wheel? That makes a pretty big difference in effective gearing. That's why gear-inches is a much better number to use when comparing gearing between bikes. The top gear on the stock TF8 is good for 25.3 mph pedaling at 90 rpm. What kind of riding are you doing that requires a higher gear than that?
  1. Trek Top Fuel 8 chain ring swapout
    By 156flash in forum 29er Bikes
    Last Post: 11-05-2015, 07:28 PM
  2. Converting my Trek Fuel to a single front chain ring
    By SycoCell121 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-26-2014, 05:53 PM
  3. replacement 32T chain ring on Bontrager Comp crankset (2001 Trek Fuel 90), 3x9 gears
    By notafreak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-08-2013, 02:35 AM
  4. What chain to run on trek fuel ex 8
    By BMSrider in forum Trek
    Last Post: 05-07-2013, 11:08 AM
  5. Trek 4900 alpha chain ring?
    By Dwhitt1981 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2011, 03:11 AM
