Trek Slash Rear triangle travel affecting Rear derailleur adjustment??- Mtbr.com
Results 1 to 2 of 2
    Vitamin Bike Added
    Reputation: MTBCanuck's Avatar
    I ride a 2014 Trek Slash which has primarily internal cable routing. Replaced the x-9 with a Gx 10 speed RD recently due to a tendency to continually seem to lose shift tuning (and randomly get chain skipping) after riding technical terrain (chunk, jumps, drops). This is a 1x0 drivetrain and with the fact that RD shifts perfectly on the bike stand and under pressure riding on roads the only thing that makes sense to me would be something happening with cable-routing and changes on cable tension somehow putting the RD out of adjustment after running through suspension travel? Do you guys think my theory is on the right track with this? I hate to go through the expense and pain in the butt factor of cable replacement if I'm missing something "simple". Thanks in advance.
    Keep the rubber side down
    Reputation: kris12ax7's Avatar
    Sometimes housing can have sharp points at the ends that catch on the cable causing inconsistent shifting, especially with suspension travel.
    Sent from my LG-H831 using Tapatalk
  1. Rear Derailleur Comes out of Adjustment
    By Honda Guy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2016, 09:40 AM
  2. Rear derailleur adjustment?
    By raven1911 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-04-2014, 06:43 AM
  3. Carbine 29 rear travel adjustment
    By Jorgebike68 in forum Intense
    Last Post: 12-24-2013, 08:32 AM
  4. Rear shock travel adjustment
    By Koin in forum Shocks and Suspension
    Last Post: 05-17-2012, 12:32 PM
  5. Rear Derailleur Adjustment
    By Max 77 in forum Beginner's Corner
    Last Post: 03-30-2011, 02:26 PM
