Too much spindle length on non-drive side?- Mtbr.com
Results 1 to 1 of 1
    Sep 2019
    I'm replacing a sealed BB on my Minnesota 3.0 fatbike. The stock BB seems to be 100 x 154ish or so - closest I could find for an inexpensive sealed BB was an Origin8 100 x 164.
    The stock BB had 2 spacers on the drive side (~4-5mm) - so basically the Origin8 BB will end up just about lined up where the stock one was on the drive side - however, the non-drive side spindle will stick out about 9-10mm more than the stock one did because the spindle will essentially be installed symmetrically relative to the BB frame shell (i.e., no spacers). Will this present an major issue? The non-drive side looks like it sticks out a crazy amount (see pic). I have about 13mm from the inside of the crank arm to the chainstay. I'm less concerned about wearing the BB down prematurely (they're pretty cheap), but worried about having some sort of weird bow-legged pedal thing going, or suffering some strange (bike-related) performance issues due to the increased Q factor.
    If running the Origin8 is a bad idea, anyone know of an alternative? Origin8 sells a 137.5 version, but I think that will be way too short. I also thought of maybe running 1 spacer on the drive side (if it doesn't impact the chainline) to kind of split the difference too.
    Attached Thumbnails Attached Thumbnails Too much spindle length on non-drive side?-img_3233.jpg
  1. Uneven wear drive side X01 crank spindle
    By Thorin_2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-24-2015, 03:43 PM
  2. Wheelbuilding - Equalized tension b/w drive & non-drive side help
    By fullCircling in forum Wheels and Tires
    Last Post: 01-17-2015, 07:30 PM
  3. Increasing psi vs increasing compression damping.....difference?
    By beachbum1 in forum Shocks and Suspension
    Last Post: 11-15-2014, 07:53 PM
  4. Replies: 26
    Last Post: 01-11-2014, 03:55 PM
  5. Changing drive side to non drive? cranks...
    By donkekus in forum Vintage, Retro, Classic
    Last Post: 01-09-2005, 12:53 AM
Members who have read this thread: 8
