Results 1 to 6 of 6
    Reputation: stingray's Avatar
    Mar 2014
    thumbless trigger shifter
    I just learned that STI shifters, for drop handlebars, shift up and down with two parallel levers that move the same direction.
    Are there any trigger shifters that one shifts up and down by clicking two buttons with just fingers (not your thumb)?
    This is a thumb arthritis concern.
    Reputation: upstateSC-rider's Avatar
    I have the Shimano lx Dual-control shifters on my 06 Stumpjumper fsr, they're basically STI mt bike sfifters.
    A lot of people hated them but I've never had a problem with them.
    They were only available for 9-spd, though, if that's an issue to you.
    Niner Jet 9 RDO, Scalpel 29, XTC 650b, 04 Stumpjumper FSR Pro, Trek Rigid SS - No suspension, no gears....no problem
    Positively negative
    Yeah, Shimano Dual Control. It's more of a push/pull situation, but you don't have to use your thumb. I actually really liked the idea but it needed some revision and the reception was bad enough to kill it entirely.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Why not grip shift? If you can hold the bars you can twist.
    Mar 2013
    Or XTR Di2. Not much of a push with electric. Does cost an arm and a leg and your left testicle plus a kidney.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    I have weak thumbs, from years of vert skateboarding. Grip Shift is the only thing I use now: fast, light, cheap, crash-resistant and never works the thumbs!
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
  1. grip twist shifter to trigger or trigger/brake lever combo?
    By |V3nom| in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-15-2015, 06:15 AM
  2. Is it worth getting X0 Trigger shifter over the X9?
    By Ramborage in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2015, 04:03 PM
  3. Replies: 0
    Last Post: 12-03-2014, 01:58 PM
  4. X0 trigger shifter
    By 09F5 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-04-2012, 04:47 AM
  5. Trigger shifter problem
    By DIRTJUNKIE in forum SRAM
    Last Post: 05-01-2011, 03:15 PM
