Results 1 to 13 of 13
    Reputation: swoodbrn's Avatar
    Switch from round to oval - longer, shorter, equal length chain?
    Going from 1x12, round 32t chainring to a 32t wolf tooth elliptical chainring, how should the new chain length compare to old - longer, shorter, same?
    ultra member
    Reputation: briantortilla's Avatar
    Same. No more teeth will be engaged at the same time when comparing oval and circular rings.
    Somersaults... that's how I roll.
    100% PRIME ALBERTA BEEF
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    I am trying the new RaceFace oval ring on my new hardtail, that I have not yet picked up from the LBS after major surgery. First oval ring for me. Not sure what to expect, except that riding it back to back with my other bikes is likely going to be a bit freaky.
    Feb 2005
    Quote Originally Posted by briantortilla View Post
    Thx. Thatís what I suspect however I also had the thought that since a portion of the chainring will have a longer radius (actually, two parts), it will pull the chain farther forward from rear wheel, requiring the derailleur to pivot farther, which might require a longer chain. Know what I mean?
    Apr 2017
    Please report back once you get some mileages in.
    Quote Originally Posted by mtnbkrmike View Post
    Reputation: Lone Rager's Avatar
    Dec 2013
    Quote Originally Posted by Wu-D View Post
    The chain goes half way around the ring irrespective of it's rotation. Half the ring always has 16 teeth so takes up the same length of chain. The included angle between the upper and lower run will change slightly but this has a very small effect on chain length.
    Do the math.
    Aug 2013
    Quote Originally Posted by Gumby_rider View Post
    I have been riding both an Absolute Black oval 1x11 setup and a round ring on a fixed gear for a while, and the difference really is not too big to worry about at all. Iím riding flat pedals on the 1x11 and spd on the fixed gear, that seems to be a bigger difference than oval vs round chainring.
    Always in the wrong gear
    Reputation: Impetus's Avatar
    Aug 2014
    Quote Originally Posted by swoodbrn View Post
    Same length. I've run an oval on a singlespeed for several years now exclusively. There's *a little* variation in chain tension, but not enough to concern anyone.
    I didn't find it 'freaky' at all. It had a moderately noticeable difference for about the length of the trailhead parkinglot, and after a mile on the trail where my attention was on riding and not my feet, I forgot about it....other than my legs felt fresher and stronger all day, and I was spinning tires in the kitty-litter less.
    Donít modify the trail to match your skills, modify your skills to match the trails.
    Reputation: targnik's Avatar
    Jan 2014
    Same length chain ;-)
    'Born to ride!'
    "Mountain biking: the under-rated and drug-free antidepressant"
    So how is the new oval treating you? Thinking about changing from 32t round to 30 oval on an eagle setup. Hoping for a little additional drive on inclines.
    Feb 2005
    Quote Originally Posted by Bills View Post
    I rode one before and liked it. I donít find there to be a huge difference but I did notice it when I got the new bike with the round on it. If you drop down to a 30t youíll definitely notice the climbability.
    Oct 2013
    I would actually replace the 32t round with 32t OVAL if you want to make it easier to climb, it would feel like a 31 or so and still have the top end.
    2019 Yeti SB100
    2016 Transition Smuggler
    Thanks for the info!
    Going to order one and then hope for better weather so I can ride with it.
  1. To Oval or not to Oval?
    By big0mike in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-12-2018, 05:14 PM
  2. Oval to round to oval to round to...
    By Lenny7 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-28-2015, 07:11 PM
  3. Edit: Dumb question, nevermind
    By trhoppe in forum Shocks and Suspension
    Last Post: 08-11-2014, 06:38 AM
  4. Replies: 34
    Last Post: 06-30-2013, 09:24 AM
  5. Equal work, equal pay?
    By Shakenbake in forum Endurance XC Racing
    Last Post: 01-16-2008, 04:15 PM
Members who have read this thread: 109
