Results 1 to 9 of 9
    Reputation: billywhiz040480's Avatar
    Nov 2012
    Sunrace 11-40t cassette and Shimano Zee Freeride RD
    Has anyone got knowledge on whether or not these two will work together? I have recently bought a Shimano Zee 10 speed Freeride rear derailleur with the intention of going 1x10 speed on a 11-36t XT cassette but then fell victim to the craze that is extender cogs. Since I have found the Sunrace 11-40t Cassette so I'm torn. The Zee cage is small but I've read that some people have successfully used the Zee derailleur with a 40t extender cog, so I just want clarification before wasting money on 11-40t Sunrace cassette as opposed to an XT 11-36t + 40t cog
    I ate all my carrotts when I was a little boy, so why do I need these lights to see in the dark???
    Reputation: mhelander's Avatar
    May 2014
    Why not. It worked great with my 9sp 11-40 put together from Hope T-Rex40 and SRAM 11-32 & 11-34 cogs. Still working great with M9000 & M8000 11s 11-40 cassette.
    Hockeys aren't great, replaced mine with Tacx ones having sealed stainless bearings.
    Sent from my Nexus 5X using Tapatalk
    Cheers,
    -Mika
    NedwannaB
    Reputation: JMac47's Avatar
    Lots of people use them with 42t ext cogs know reason it won't work on an integral cassette.
    What model Sunrace are you looking to get, the ms or mx?
    Wait whuuut, who did he tell you that!?!?....
    Nov 2012
    NedwannaB
    Quote Originally Posted by billywhiz040480 View Post
    Cool. I need to find that style here in the states. 👍
    Nov 2012
    Quote Originally Posted by JMac47 View Post
    ebay british seller 'roteccycles' (59.89) will post to the US for 4.99 with an expected delivery of between November 24th-December 4th, that converts to $98.71.
    SunRace MX3 Cassette MTB 10 Speed 11-40t Wide Range Shimano SRAM compatible | eBay
    Nov 2012
    So in the end I went:
    Shimano Zee Shadow plus. (34.99)
    Shimano XT 10 spd Shifter. (27.99)
    Shimano XT 10 spd 11-36 Cassette.
    Shimano XT 10 spd Chain.
    Absolute Black 40T Extender cog.
    Absolute Black 13T Lock Ring. (50.00)
    Basically I bought the lot apart from the shifter and derailleur from a guy on Pinkbike in mint condition for 50 less than 300 miles old. It did take a little fettling with the B-screw (original used) and Hi\Low adjustments but now I've got them shifting perfect. The only cog you loose is the 11T as the 13T lock ring does its magic.
    Absolute Black 13T Lock Ring:
    'There are two ways to fit 40T sprocket to your drivetrain. You can remove the stock 17T sprocket and one spacer from your cassette, then put 40T on the freehub and mount everything else back (except 17T).
    OR, by removing 11T sprocket. Second option is a lot better in our opinion, but requires our special lockring to hold 13T sprocket (lockring is available in options).
    If you don't know which option would be better for you, then just go for a ride and observe which of these two sprockets (11 & 17) you will miss less. Study shows, around 90% of mtb riders do not use 11T sprocket in terrain.'
    absoluteBLACK | Parts | Extender COG + 13T lockring
    Jan 2009
    The trouble I have with adding an extender and removing the 11t is that you're decreasing the range of the cassette (vs 11-40). What size chainring are you running? It makes sense if you're already at a 30t and limited by crank I suppose.
    Little Gear:
    30/36=0.83
    32/40=0.8
    Big Gear:
    30/11=2.72
    32/13=2.46
    Reputation: watts888's Avatar
    Oct 2012
    Cool. I need to find that style here in the states. 
    go to your LBS. Easy. I just ordered an 11-42, no problem. Should cost under $70 after a 10% "I buy too much stuff" discount.
    Don't know about short cage vs.long cage with the Zee, but the only problem I've heard with the shimano derailure is needing a longer B screw with the 42T. Don't know if the 40T cog needs it, but it's a screw. Not hard to find at a hardware store.
    "a hundred travel books isn't worth one real trip"
  1. SunRace cassette , wide range
    By johnD in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-18-2018, 01:34 AM
  2. Sunrace CSM99 9-Speed 11-36T Cassette.
    By Ronnie in forum 29er Components
    Last Post: 10-07-2016, 11:40 PM
  3. Sunrace 7 speed 11-34 cassette
    By TLD80 in forum Families and Riding with Kids
    Last Post: 06-06-2015, 12:32 PM
  4. sunrace cassette, supposed to have some play?
    By doabackflip in forum Specialized
    Last Post: 05-08-2014, 06:04 AM
  5. Sunrace m96 cassette
    By jeremyreed in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2014, 10:34 AM
