Results 1 to 9 of 9
    Apr 2005
    stripped thread on Raceface carbon crank
    I installed a left side flat pedal improperly causing partial stripping of thread.
    Is there a way to restore the thread groves?
    can bike shop send it out for repair?
    Reputation: life behind bars's Avatar
    May 2014
    Run a tap through it before committing to expensive repairs.
    Wanted, SRAM GX 2x11 rear derailleur
    It ain't supposed to be easy.
    Apr 2005
    Quote Originally Posted by life behind bars View Post
    huh? what do you mean run a tap?
    May 2014
    Quote Originally Posted by Picard View Post
    https://www.kmstools.com/blog/hand-t...ng-techniques/
    Reputation: Lone Rager's Avatar
    Dec 2013
    If the threads aren't jacked too bad, you can thread a left pedal in from behind the crank arm where the threads are still good and use it to straighten the threads. Use a pedal that has long enough threads to come through the crank arm. Grease well.
    The pedal spindle will reform the threads. A tap might work, but it will remove material. If you use a tap, run it in from behind the crank arm so it is guided by the good threads.
    Do the math.
    Apr 2005
    can bike shop mechanic run the tap? I have no tools to do this stuff.
    Mar 2011
    Yes, a good shop will have both taps, left and right.
    What? There's more?
    Reputation: tyrebyter's Avatar
    If it's too far gone to sort out with a tap, have a Heli-Coil installed. Not all shops will offer that, but I just had one done at my LBS and it was $35US. That's a lot less than replacing some crank arms.
    Dec 2013
    A helicoil is great if done properly. It's the properly part that can be tricky. I fixture the crank in a drill press or milling machine to ensure the bores and threads wind up straight and true.
    Do the math.
  1. Crank pedal spindle hole thread stripped
    By cpamieta in forum General Discussion
    Last Post: 10-01-2018, 05:34 PM
  2. Replies: 19
    Last Post: 01-20-2016, 05:43 AM
  3. Replies: 9
    Last Post: 09-17-2014, 02:01 PM
  4. stripped crank thread. FML
    By jeeper006 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-26-2013, 06:59 PM
  5. crank removal tool stripped my thread, now what?
    By ashsimmonds in forum General Discussion
    Last Post: 04-06-2007, 09:39 PM
Members who have read this thread: 55
