Results 1 to 8 of 8
    Reputation: SoftballGuy's Avatar
    Jan 2014
    Steel chainring durability
    Have a 2x9 (40/27) drivetrain-- shifts fine, but chain is @ .75 so thought i would replace it. Alot of grinding on the small ring now. Chain won't release from the teeth,all kind of chainsuck. If i switch to the barely used large ring, no issues.I need a new ring i assume? I put a steel one on 9 months ago because i was tired of replacing the alloy one every 6 months. I was expecting a few years out of it, so i haven't even bothered to check it. The teeth look sharp--after just 9 months? Disappointing for sure, i thought steel had alot more durability. I have 86bcd (no aftermarket avail) so i can only buy OEM rings from FSA.
    Sounds like FSA might not be heat treating their steel rings properly if at all. Might want to try and heat treat the next one yourself and see if you get better results.
    Or you might screw things up even more. I honestly pulled this reply out of my @ss so do what you want.
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by SoftballGuy View Post
    Was the chain new at that time? A worn chain will prematurely wear out a chainring. I get several thousand miles out of alloy chainrings but I replace chains quite regularly.
    Jan 2014
    I put on a new chain at the time, have already replaced it once, now replacing again. I found a slightly used alloy chainring, i flipped it and put it on, seemed to solve that issue, however now my cassette is slipping under load. Cassette is a yr old but looks like i'm off to the LBS for a new one. Wasn't expecting a simple 5min chain replacement to open a can of drivetrain worms. Maybe i should replace chains at .5 instead of .75.
    This has more to do with the gear than the chain. I had a 34 teeth Alivo lock up on me in traffic. Since then I have went back to gears with out ramps and pins. A 34 will last around 20000 miles. a 27 will last around half that. It will also lock up under a smaller chain stretch. I can run mine to 1.25 percent. They get noisy but don't lock up. https://www.flickr.com/photos/633739...posted-public/
    "Dish is illogical." Spoke of Vulcan.
    since 4/10/2009
    Reputation: Harold's Avatar
    I replace chains at .5. I get 2-3 chains per cassette and a few cassettes per chainring change at least on my old multi-ring setups. I am new to 1x, so I haven't been through a full drivetrain change on that yet. Still, I've got about 900mi on my 28t alloy NW chainring and it still looks quite good. I got about 600mi on my first chain on that bike to the .5 wear point, though, so I'm well into my 2nd chain now. Cassette is still good, though.
    Quote Originally Posted by Harold View Post
    That's about my ratio. I don't even measure, I just replace my chain every 500 miles or so.
    Jan 2014
    FSA also makes a 28T and a 30T replacement. I don't know if a 28T would really make a difference on durability. Maybe getting a 30T would extend ring life,it only comes in alloy though. I don't know if it would clear the chainstay, i assume it would, i have about an 1" clearance with the 27T.
  1. Sram XX1 11-SPEED Chainring durability....on Jet9rdo
    By Surfdog93 in forum Niner Bikes
    Last Post: 10-13-2013, 10:25 AM
  2. XT 22t steel chainring? Help needed.
    By eatdrinkride in forum Arizona
    Last Post: 10-06-2013, 12:01 PM
  3. Steel or aluminum chainring?
    By Blue Sugar in forum Singlespeed
    Last Post: 07-30-2013, 01:14 PM
  4. Steel or AL Chainring bolts?
    By mcoplea in forum Singlespeed
    Last Post: 04-10-2013, 05:09 PM
  5. Crank for 1x10 with steel 28T chainring?
    By Svend P in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-22-2012, 05:37 AM
