SRAM XX BB30 or GXP crank for BB90 BB ???- Mtbr.com
Results 1 to 6 of 6
    Sooz
    Reputation: sooza's Avatar
    Feb 2012
    I have a Trek TopFuel 2011 9.9 with a BB90 BB (bearings installed in frame). I recently purchased a SRAM XX BB30 crank off eBay and have since discovered the BB30 will not fit in my frame From what I can research, it is the SRAM XX GXP crank that I need. I would appreciate it someone would confirm this.
    The joy of ski is Yours
    Reputation: Haint's Avatar
    Be sure to get the BB90.
    I like Sand - I don't like Witches
    Sooz
    Feb 2012
    Please excuse my ignorance but what do you mean? My TopFuel has a BB90. What crank should I buy? GXP ?
    GXP applies to almost all SRAM BB - it's just a Seal configuration. If BB90 is supported, that's what you have to get; 90/92 is the BB Shell width and they have to drop in.
    I just looked quickly at SRAM cranksets and BB30 is the only press-in I can find. The standalone GXP is threaded.
    I already posted this in your cross post in General Discussion:
    Yes, you need the GXP crankset. You will need the Trek BB for GXP.
    http://forums.mtbr.com/trek/trek-bb9...ms-776481.html
    Make sure you research this - looks like the Top Fuel takes a special BB, something about a narrow Q-factor. The Enduro page has a warning:
    FRAMES THIS KIT WILL NOT FIT:
    --Trek mountain frames with BB90 bottom bracket shells.
    (Top Fuel Carbon and Hardtail Carbon)
    Sooz
    Feb 2012
    Quote Originally Posted by Slash5 View Post
    Thanks again Slash. I purchased the XX GXP crank and correct BB. Installed and riding now.
  1. SRAM XX BB30 or GXP for BB90 BB ???
    By sooza in forum General Discussion
    Last Post: 12-12-2013, 11:09 PM
  2. SRAM BB30 crank in MTB OSBB help
    By tootall in forum Specialized
    Last Post: 10-22-2012, 11:11 AM
  3. BB30 frame with Shimano BB90 XTR crank. HELP!!!
    By eduluke in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-30-2012, 07:02 AM
  4. Using a SRAM XX GXP Crank in a BB30 Frame
    By flafonta in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-15-2011, 08:18 AM
  5. Flash and Sram XX BB30 Crank
    By roadrunner in forum Cannondale
    Last Post: 06-13-2011, 02:16 PM
