Results 1 to 2 of 2
    Sep 2013
    SRAM X1 Change 10T to 11T
    Hi,
    I was wondering if it's possible to change the 10T cog to an 11T cog on the 11 speed SRAM X1 casette? I find the jump from 12T to 10T to be too extreme. Also, I run a 32T in the front so I don't really need more top end. I think 11x32 will be plenty fast.
    I'm not sure about swapping one cog, but you could get a Shimano cassette 11-42.
    Just be aware that 1 tooth makes a big difference, since it is 10% of the small cog. A 32x10 is around the same ratio as a 35x11, so you give up quite a lot on the high end. Put another way, you could keep the 10 and have a 29T chainring and have the same high end as the 32x11, with a much better low.
    I don't hear this complaint much, and it might mean that you are spending too much time on the small end of the cassette. You could consider a bigger chain ring, which would keep you more toward the middle-big end, and you might no longer care about the 12 to 10 drop.
  1. How to change this bike to 2x10 SRAM?
    By Go29er in forum 29er Bikes
    Last Post: 06-06-2012, 05:34 PM
  2. cable change on sram 9.0 grip shift
    By 29ernb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-23-2012, 12:32 PM
  3. Change SRAM S-2200 on Stumpjumper to Single Ring
    By altezza2k2 in forum Specialized
    Last Post: 02-06-2012, 04:38 PM
  4. Change Gripshifter to SRAM X3 Triggers?
    By Wolfie1992 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-11-2011, 05:37 PM
  5. Sram X0 rear derailleur change from Long to short cage
    By arashi in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-01-2011, 02:20 PM
