SRAM X01 11-Speed X-HORIZON™ Rear Derailleur compatible with sram 10 speed ?- Mtbr.com
Results 1 to 6 of 6
    Sep 2013
    I'm in need of a new R.D., I currently use Sram xo 10 speed and would like to stay with 10 speed for now. I can see going to Sram 11 speed on my next build this summer...Question, will XO 11 speed R.D. work with my 10 speed shifters ??
    Thx.
    dadamamabooboo
    Reputation: bigchillcar's Avatar
    Aug 2014
    i'm gonna say yes it will work. as long as the rd can handle the cassette range, shouldn't be a problem. an obvious example would b trying to use a 7-speed derailleur on a 10-speed cassette..just doesn't have the range, but in your case it has greater range than needed. shifters must match cassettes though as they have differing pulls.
    hopefully someone will correct if i'm wrong about a 11-speed rd.
    2011 Trek Mamba 29er 21", SRAM 10-sp X9, X9 type 2 RD, SRAM X7 20(oval)/36 & SRAM X9 2X FD, Shimano XT M771 11-36, M525 hub
    Dec 2004
    Sram XO1 and X1 rear deraileur does not work with sram 10 speed shifter.
    If you are running it 1x10, look into the XO-1 DH derailleur that was designed for 10 speed.
    Dec 2004
    The xo1 dh max rear cog is 28t. I know with shimano you could push the limits about 4 teeth. With sram I do not have any idea. 36t is a long way from 28t. Would someone drop the $280 and get the derailleur in question and tests its limits
    come to think of it, a cx1 deralleur will handle a 36t and work with 10 speed shifters.
  1. Sram TYPE 2 10-Speed Rear Derailleur with 9-Speed cassette + -speed Gripshift
    By jaxson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-02-2014, 09:43 AM
  2. Sram XX1 X Horizon RD as a 10 speed?
    By Sand Rat in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-15-2013, 06:13 PM
  3. Are the new SRAM 10 speed rear derailleurs compatible with 9 sp drivetrain?
    By ride_nw in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-09-2012, 11:07 AM
  4. Looking for SRAM XO 9-Speed Rear Derailleur
    By RRBinTempeAZ in forum Arizona
    Last Post: 11-24-2011, 01:46 AM
  5. Sram XX rear derailleur in 9 speed system?
    By Eknor in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-17-2011, 09:42 AM
