Results 1 to 11 of 11
    Apr 2013
    SRAM gx 1x11 adjustment screws
    Does anyone know which screw is the high and which is the low adjustment screw. I'm guessing the screw on the bike side is for the smaller cog, and the screw on the outside is for the larger cog. Anyone know?
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    You will have better luck in the Drivetrain forum.
    I got some bad ideas in my head.
    Ride Everything
    Reputation: GRAVELBIKE's Avatar
    GRAVELBIKE.COM - ride everything
    Reputation: Steel Calf's Avatar
    Feb 2010
    Quote Originally Posted by Johnmatrix View Post
    That's a serious question. Impossible to find out by yourself. It actually reminds me of the "does somebody know with which side up I plug in the USB drive into the usb port" from the computer forums
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    Quote Originally Posted by Steel Calf View Post
    Translation: you'll find out for sure as soon as you just try adjusting the screws.
    Note, generally speaking you're first instinct is correct. Try the inside screw first.
    Old enough to know better. And old enough not to care. Best age to be.
    Mar 2011
    I just got a bike with SRAM GX 1x11 rear derailleur and I can't figure out how to adjust it properly (gears keep jumping up and down on the largest cogs in the rear).
    The manual at SRAM site is totally useless for this model. In the images in the manual there is some other SRAM MTB derailleur that has different adjustment screw placement..
    Feb 2010
    Quote Originally Posted by lemons0 View Post
    cable tension needs to be adjusted, that is done at the shifter.
    I think you're looking for the wrong type of information. What may help you is a document explaining the underlying principles on how a bicycle gearing actually works
    Mar 2011
    While you are correct in that I need to study more about how bicycle gearing works, I find it unacceptable that SRAM doesn't have a proper manual for a gearset that costs this much. All they have is a generic manual for "MTB gears" and what they show there is very different from the GX derailleur.
    Ride Everything
    Did you confirm that you routed/attached the cable correctly for your particular derailleur? The docs (see link below) indicate that it's different for the GX 1x11, 2x11, and 2x10 models.
    The doc also has a brief troubleshooting section near the end (around page 19).
    https://sram-cdn-pull-zone-gsdesign....rs_emanual.pdf
    Anytime. Anywhere.
    The OP is right. His derailleur is very different from the ones in SRAMs manual. Someone must have found the adjustment screws.
    Anytime. Anywhere.
    The high & low adjustment screws are on the back of the derailleur.
  1. HELP! SRAM 1x11 conversion.
    By UnluckySamurai in forum 29er Components
    Last Post: 09-01-2015, 08:11 AM
  2. SRAM 1x11
    By Josepht1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-06-2015, 04:06 PM
  3. 1x11 with a non-sram chainring...
    By mhopton in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2014, 04:11 PM
  4. 3 small screws for Sram GXP Spider....
    By edle in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-31-2013, 07:07 PM
  5. SRAM XX1 Drivetrain 1x11
    By eurospek in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-29-2013, 08:13 PM
Members who have read this thread: 17
