Results 1 to 10 of 10
    Nov 2015
    SRAM GX 1400 vs Race Face Aeffect 1x crankset
    Trying to decide between these two cranks for new build. Anyone have an opinion between these? Best deal I can find is 150ish for either set.
    Reputation: OwenM's Avatar
    Oct 2012
    They're pretty similar. I just got the SRAM a couple of weeks ago, and could have gone either way.
    The SRAM is maybe a bit lighter based on the specs, and the GXP bottom bracket is inexpensive, but I really just preferred the plainer look.
    Both available in 170 or 175mm. The SRAM uses 3 Torx screws to hold the ring(don't know the technical name for it) that secures a direct mount chainring, while the RF uses the Cinch ring, which I believe works with an ISIS drive.
    I didn't really read up on the Aeffect, but don't know that there is any practical difference between them.
    Reputation: RS VR6's Avatar
    It's going to be a wash in weight and performance between the two. It'll come down to price and whichever one you like better.
    I have the XX1 crank, and the three torx bolt on the SRAM spider is just waiting to be stripped. Make sure you use a sharp Torx and that it's all the way in the bolt. If you plan on switching rings often...maybe the Cinch will be a better setup.
    Ride Everything
    Reputation: GRAVELBIKE's Avatar
    My new bike came with Aeffect cranks as OE. Stock ring was a DM 32t, but swapped it for a 30t Wolftooth DM ring. Changing the ring was easy thanks to the Cinch design. My other bike has carbon SRAM 1x cranks, and to be honest, I can't detect any difference in stiffness.
    GRAVELBIKE.COM - ride everything
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    I have the Next SL and the Cinch system is great. Very easy to remove cranks and change rings.
    I got some bad ideas in my head.
    Nov 2012
    Beware that 170mm aeffect are re-drilled 175mm, so no added clearance.
    Beside this they are nice and looks durable with steel axle and bolt (already stripped a RF turbine alloy bolt once).
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    Quote Originally Posted by RS VR6 View Post
    Yup... beware of those blasted torx... I just wrecked a GX crankset... stripped the head on one and basically destroyed the bolt... I miiiiiight be able to salvage them by getting the bolt drilled out but i bet the threads are f***ed.
    I'm gonna be shopping a Race Face in the coming days...
    Santa Cruz Hightower LT
    Jan 2009
    Any idea if I can use a Race Face chainring on this crankset that came on my Stumpy 6fattie - Custom SRAM GX-1000, PF30 spindle, 28T, direct mount? I'm wanting to put a 26T on.
    RAKC
    Reputation: tigris99's Avatar
    No sram and race face direct mount rings are not interchangeable.
    Sent from my XT1565 using Tapatalk
    Jan 2009
    [QUOTE=tigris99;12883436]No sram and race face direct mount rings are not interchangeable.
    I see that there is a SRAM Race Face chainring (as opposed to the Cinch ones)- not sure if it works with my GX cranks though
    https://www.amazon.com/Race-Direct-M...ce%2Bsram&th=1
  1. Opinions/reviews on race face aeffect crank w cinch/direct mount???
    By mcmars in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-31-2017, 12:31 PM
  2. HD3 and Race Face Next SL crankset....
    By k2rider1964 in forum Ibis
    Last Post: 01-11-2016, 02:34 PM
  3. Opinions all welcome. Race Face Next SL or SRAM X01 crankset
    By Pock in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-03-2015, 10:16 AM
  4. Questions re: SRAM XO Crankset/Niner Jet 9 Frame/Race Face Narrow/Wide
    By June Bug in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-14-2014, 07:00 AM
  5. Race Face Next XC '10 crankset with 2x or 1x?
    By RaikkuFIN in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-24-2013, 02:40 PM
Members who have read this thread: 26
