SRAM Eagle chain with xx1 (non-eagle) chainring.- Mtbr.com
Results 1 to 6 of 6
    Feb 2006
    I've found only one person that has this setup with no problems, though over a relatively short time frame. SRAM makes clear that the new eagle system isn't compatible with the X-SYNC chainring.
    Anyone have any direct info on why SRAM says they are incompatible? Would the chain wear quicker? How about the cassette? Would the x-sync chainring reek havoc on the chain and thus muck up the other bits of the drivetrain?
    West Chester, PA
    Yep. The aluminum chainring will destroy the steel chain, which will then magically transfer abnormal wear to the (mostly) steel cassette. Then the monster under your bed will have it's way with you in the middle of the night... And, BAM! Herpes! Don't get herpes. Buy the eagle cranks.
    Feb 2006
    Quote Originally Posted by 92gli View Post
    There's a monster under my bed??? Oh shiite!!!
    Reputation: flipnidaho's Avatar
    I run Eagle on a couple of bikes with Next SL 11 spd chainrings with zero issues and on another bike with an XT 11spd chainring with no issues.
    Feb 2006
    Quote Originally Posted by flipnidaho View Post
    Much thanks!!
    I'm pretty stoked as I just picked up the mini groupo. I'm popping it on my Specialized SWorks Stumpy when it arrives next week.
    By chance you ever try running the aforementioned with an 11 speed SRAM chain? Or did you go straight to Eagle chain?
  1. Has anyone tried M8000 (XT) 1X chainring with the XX1 Eagle chain?
    By flipnidaho in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-17-2018, 04:17 PM
  2. SRAM Eagle Smallest Chainring?
    By LyncStar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-27-2017, 11:45 PM
  3. Sram 11 speed X-Sync Chainring with Eagle Group?
    By heathw in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2017, 06:53 PM
  4. Sram Eagle chain backwards compatibility
    By demc1982 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-24-2017, 09:50 AM
  5. eagle x01 chain dropping off chainring
    By useport80 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-17-2017, 07:25 AM
