Results 1 to 8 of 8
    Reputation: crankpuller's Avatar
    SRAM bottom bracket + shimano crank compatibility?
    I have a SRAM gx (24mm spindle) bottom bracket and just got a new shimano xtr crank- also 24 mm.
    Are there any compatibility issues?
    Mike
    Sent from my Pixel 2 XL using Tapatalk
    Reputation: Lone Rager's Avatar
    Dec 2013
    I believe your Sram crank is GXP, which has the NDS end of the crank spindle stepped down to 22mm. Shimano cranks are straight 24mm so won't fit through the NDS bearing in a GXP BB.
    I have seen a GXP bb where the 22mm bore in the NDS bearing was created with a reducing insert with a shoulder that created the correct inner race length and offset for GXP. It was possible to remove the insert to fit a Shimano crank. Out of a lot of BBs, I've only seen this one time.
    Do the math.
    Quote Originally Posted by Lone Rager View Post
    It's a SRAM bb92 - would that be different than the GXP?
    Jan 2009
    Quote Originally Posted by crankpuller View Post
    Put simply, you will need a Shimano BB92 if you want to use that Shimano crank.
    Dec 2013
    Right. BB92 basically refers to the BB fitting the frame shell. The BB you get also needs to fit the crank spindle. A GXP spindle is stepped 24/22 mm whereas a Shimano crank is straight 24mm. And, of course, some spindles won't fit a given frame no matter the BB if the spindle is too short or too big in diameter.
    Do the math.
    Awesome- thanks!!!
    since 4/10/2009
    Reputation: Harold's Avatar
    If you want to be technical, a BB92 bottom bracket specifies both a 41mm ID bb shell (92mm wide) AND a 24mm STRAIGHT spindle.
    The wording SRAM uses for their BB that fits the same frame (and GXP stepped 24/22mm spindles) is PF GXP. Same bb shell, different crank.
    It's best not to go too far beyond that, because bottom bracket naming conventions suck balls. Someone who makes a bunch of different bb's needs to step in (like how Cane Creek did for headset sizes) and clear up the muckymuck bb naming.
    Reputation: yeti575inCA's Avatar
    Dec 2011
    I agree
    Sent from my SM-G930T using Tapatalk
  1. BB/Crank compatibility headache - PF92/BB92 crank compatibility
    By griffsterb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-30-2017, 06:55 AM
  2. Eagle XX1 crank compatibility with shimano xt sm-bb70 bottom bracket
    By wakebrdr142 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-19-2017, 08:15 PM
  3. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
  4. Shimano XT crank requires Shimano Chain? SRAM rear compatibility
    By LookerBob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-07-2013, 02:05 PM
  5. Shimano 10 speed crank bottom bracket compatibility ? Press fit
    By natzx7 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-14-2013, 04:19 PM
Members who have read this thread: 38
