Results 1 to 3 of 3
    Sep 2015
    SRAM 10 speed Cassette Setup Help
    I was trying to put my cassette over onto my new wheel and messed up the order that the gears and spacers were in. Would anyone know of a diagram or something to help put the gears and spacers back in their correct order? It's a SRAM PG-1030 on a 2016 Specialized Stumpjumper FSR 650b Comp. Maybe if someone knows they could number order these from the inside of the wheel to the outside starting from the top left? Any help would be much appreciated!!
    Mar 2014
    1. The 2 gears with aluminium spider (top left)
    2. Aluminium spacer with internal key way (2nd from left at bottom)
    3. Gear. (Number written on it, so bigger first)
    4. Spacer (all equal)
    Gear
    Spacer
    Etc. Until the 2 last gear which no spacef between (integrated in last one)
    Finish with threaded cap (middle at bottom)
    Dudette
    Reputation: petey15's Avatar
    Quote Originally Posted by Yougi View Post
    Gear
    Spacer
    Ha ha ha - I had the exact same thing happen and was searching everywhere for the correct order - figured it must make a difference where the metal spacer with key was put. Thank so much!
    Guerrilla Gravity BAMF, RideGG, Cycle-CNY
  1. 6 speed cassette on SS hub....Please post your setup
    By longdrive55 in forum 29er Bikes
    Last Post: 08-16-2018, 09:01 PM
  2. SRAM 11 speed deralier with 10 speed shifters and cassette
    By HBSURFDAD in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-26-2015, 02:36 PM
  3. Mavic Crossride with SRAM PG-1030 & SRAM X9 10 speed setup
    By OneBikeGuy in forum Wheels and Tires
    Last Post: 03-27-2015, 09:03 PM
  4. Sram TYPE 2 10-Speed Rear Derailleur with 9-Speed cassette + -speed Gripshift
    By jaxson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-02-2014, 09:43 AM
  5. SRAM Crank X7 GXP 3.3 - Triple 10-Speed with 9 Speed SRAM cassette
    By kragu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-07-2011, 08:42 PM
