    Formerly PaintPeelinPbody
    Reputation: PHeller's Avatar
    Dec 2012
    Square Taper Crank with External BB - 24mm Spindle Adapter?
    Ok, so BMX guys have been using after spinder/BB configuration for awhile. Basically, you select the square taper crank of your choosing, and select the BB/spindle seperately.
    Like this:
    Has anyone seen a setup that allow you to run square taper MTB cranks with an external BB setup?
    GIS/GPS Pro using ArcFM for Utility Mapping - Always willing to connect with other MTBers in the industry.
    Reputation: SFBMRC's Avatar
    Not to my knowledge. There is not a BB on the market that uses a square taper setup with external bearings.
    Why would you want that?
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    You'd be combining the worst of both worlds. Also, there might be insufficient space to fit an external cup between the BB shell and cranks. Depends on spindle length and shell width of course.
    Only reason BMX people do that conversion is that their frames don't fit a Shimano UN-55, which you can fit and forget for a very long time of quality riding time.
    White Industries does make a square taper BB with separate cups if that's your thing. It is a light piece compared to regular BB cartridges.
    Dec 2012
    Quote Originally Posted by Saul Lumikko View Post
    Holy crap I forgot how cheap those were. Nevermind, disregard, going that route instead.
    Gonna run a Wolftooth 94BCD Narrow-Wide on a Cook Brothers F-Type crankset. Trying to reuse some old parts on my wife's new bike.
  1. best adapter for BB30 to 24mm spindle?
    By Schwim Dandy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-10-2015, 06:14 PM
  2. where to get a external bottom bracket and square spindle .............
    By got6ponies in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-12-2011, 07:20 PM
  3. Square Taper Spindle Length
    By jiminyt in forum Singlespeed
    Last Post: 07-27-2011, 01:08 PM
  4. What would you do? Square taper vs External
    By stumblemumble in forum Turner
    Last Post: 07-18-2011, 01:44 PM
