single speed crank with 9spd rear? or maybe go double crank?- Mtbr.com
Results 1 to 8 of 8
    Reputation: willymcd's Avatar
    I never use my granny gear and rarely use my large ring, so i was thinking of throwing a SS crank on my moots ybb. will this work well, do i need bash guards to keep the chain from derailing since i am using a 9spd cassette? i was looking at the white industries eno SS crank, lightweight and not to pricey. or also was looking at their mtb VBC crank with 2 rings. what do you guys recommend for this kind of setup?
    this bike will be used for a mix of trail and short track racing.
    also was thinking about these (FMF BMX crank arms) herd some other people are using them. Plus they are wicked cheap and light???
    I dont think the ENO cranks will work
    I am thinking of making a 1X9 also and the eno cranks are designed for an 8sp chain.
    You will need a chain guide, I just purchased the Rolloff chain guide from Speedgoat.
    Still looking for cranks.
    Correction
    Check out the thread below: sounds like the ENO cranks will work!
    http://forums.mtbr.com/showthread.php?t=421683
    Can either of you tell me how this worked out for you?
    I'm going to buy the cranks this week
    Hopefully I will have it running in 2 weeks.
    I emailed White Industries and they said they have heard people using them as 1x9 cranks but they recommend the use of an 8 speed chain or single speed chain.
    Can someone please chime in on there experiences?
    The cheap route is to use a crank set you already own with a an unramped ring. I use a 32 tooth Blackspire ring on the hard tail I have set up this way. You will need some sort of system to keep the chain from flopping off of the ring. Some people use a bash guard or an old big ring in combination with something called a jump stop. I use a front derailleur that I've adjusted to sit right over the chain line.
    It's a great set up, the 1x9 thing.
    "Bikes aren't fast--people are fast. Bikes are overpriced. It's an important distinction."---BikeSnob NYC
    Quote Originally Posted by Phantomtracer
    I have been running this setup with a 9 spd chain for awhile now with no problems. I honestly didn't know that they only recommended a 8 speed chain. It works flawlessly with the Rholoff guide.
    Works Great
    Quote Originally Posted by mikesgroove1
    Only issue is the eno cranks have a low Q factor which makes it more difficult to set up a Rohloff chain. I have one full ride on them and it shifted great, no dropped chain. I would recommend the 122mm BB for most bikes, the 113mm was to tight for my bike. White Industries website gives measurements for figuring the BB size - it is incorrect .
