Results 1 to 5 of 5
    Dec 2014
    should I go long cage crank?
    Hello guys,
    I got 1x10 drivetrain. front 32 t, rear 36t-11t.
    if I use the "formula" - I get:
    T = (32-0)+ (36-11) = 57.
    I know that:
    Shimano
    Long = 45T
    Medium = 33T
    Short = 28T
    SRAM
    Long = 45T
    Medium = 37T
    Short = 30T
    does it mean I need to go long cage? currently I think I got a small or medium cage (can you tell what length exactly it is?) and run o.k. I think. should I change it anyway?
    there is the picture my derailleur:
    https://s1.postimg.org/ynrfsulcf/20151017_180616.jpg
    thanks
    Oct 2007
    You did the calculation incorrectly. Because you have only one ring in the front you do not need to include it in your calculation. Your calculation should simply be 36-11 which is 25.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Reputation: J.B. Weld's Avatar
    Edit: or what ljsmith said^^
    Your formula is wrong, you don't need to consider the front chainring because you only have one, with 2 or 3 chainrings you add the difference between them. In your case the total spread is 25t so a short or medium cage derailleur will work fine.
    Dec 2014
    thanks very much
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Math is fun!
  1. What is the difference between SRAM RD long cage/short cage pulleys?
    By gibsonlespaulspecial in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2015, 05:17 AM
  2. Shimano Exage Long Cage vs. Acera Long Cage
    By jeffj in forum Vintage, Retro, Classic
    Last Post: 11-12-2013, 05:53 AM
  3. Need Help-Can I use X9 Long Cage Pulley/Spring Assembly for XO Rear Derailleur Cage?
    By red bank rider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-10-2013, 09:58 AM
  4. Medium or Long Cage RD with 11-36 cassette & 26-38 crank on VPP bike
    By mmhsval in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-07-2013, 03:26 PM
  5. Stay w/ long cage deraileur or switch to a med cage?
    By Tfrost in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-14-2011, 09:35 AM
