    Reputation: stingray's Avatar
    Mar 2014
    Short or long cage derailleur?
    I have a 48-38-28 triple crank with a 25-12 cassette. I need to buy a replacement 9-speed rear derailleur, but I am not sure if I need a short or long cage. The specs for each are below. Looking at the numbers, it would seem that I could use either one, but would appreciate confirmation from a more experienced person.
    Model Number : Shimano SORA RD-3500-SS
    Cassette Compatibility : 9
    Maximum Sprocket : 32T / 14T
    Minimum Sprocket : 25T / 11T
    Maximum Front Difference : 16T
    Total Capacity : 37T
    Model Number : Shimano SORA RD-3500-GS
    Maximum Front Difference : 20T
    Total Capacity : 41T
    Guest
    You're running a 20T chain ring difference so, based on the information you provided, you need the long cage. It appears the short cage would otherwise work, but I don't know that I would install something that the mfg didn't spec for. What came off the bike?
    Mar 2014
    I currently have a long cage. It makes sense now. After counting teeth on two bikes I glossed over the max front difference spec. You have been helpful. Thanks.
    Guest
    Quote Originally Posted by stingray View Post
    No worries. These things get easier to figure out with experience. You're going to find yourself getting a lot of that pretty quickly in this sport/hobby.
  1. When to use a Long Cage vs Short Cage Derailleur?
    By Trentkc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 2 Weeks Ago, 08:23 AM
  2. When to use a Long Cage vs Short Cage Derailleur?
    Last Post: 01-04-2016, 02:03 PM
  3. Long, med, or short cage derailleur?
    By XandX2005 in forum Downhill - Freeride
    Last Post: 03-25-2013, 03:58 AM
  4. Chain length and short vs long cage derailleur
    By Cormac in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-25-2011, 11:38 AM
  5. Long/Med/Short derailleur cage which one??
    By YamiRider1316 in forum All Mountain
    Last Post: 03-31-2011, 11:34 AM
