Results 1 to 12 of 12
    May 2014
    Short cage capacity
    In 1x10 mode with 38 tooth front chainring, can a short cage Shimano Ultegra 6700 rear derailleur handle an 11x32 rear cassette? Some sites say yes and others say up to 28.
    bt
    bt is offline
    Nov 2007
    no.
    May 2014
    bt
    bt is offline
    Nov 2007
    there is a difference in the definition of "max cog capacity" and what the "largest rear cog" a derailleur can handle.
    one has to do with long or short cages, the other has to do with the largest cog size.
    the jenson ad says it can handle a 30t cog size max. and a 30 cog capacity.
    the merlin ad says depending on cage length, it can handle either 33 or 39 cog capacity, but doesn't mention max cog size.
    I have tried a 32 max cog size and it wouldn't work.
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by bt View Post
    Yep^ 2 different things, though the former is generally referred to as 'max total capacity' Shimano says 28t max cog size for both the ss and gs models but the gs has a 39t total capacity vs. the short cages 33.
    I'd go for a mtb derailleur for better results.
    May 2014
    Quote Originally Posted by J.B. Weld View Post
    Using drop bars and already have shifters so have to use road style derailleur to be compatible with my shifter. It sucks big time cause I wanted to use a clutch derailleur but I am going to have to settle for a road to compat with my shifters.
    A 9 speed Shimano MTB rear derailleur will work fine with a 10 speed or less Shimano road shifter.
    May 2014
    Quote Originally Posted by Slash5 View Post
    That's what I heard but they don't make a 9 speed with a clutch right?
    Correct.
    NedwannaB
    Reputation: JMac47's Avatar
    No way to use a 10 spd Shimano mtn der and modify/offset cable attachment similar to the SRAM 9 shifter/Shimano 10spd der? Or is pull that much different from 9-10?
    Wait whuuut, who did he tell you that!?!?....
    Actually, it looks like a Jtek Shiftmate 6 would work.
    Shifter - Shimano 10 speed road Derailleur- Shimano 10 speed MTN Cassette - SRAM / Shimano 10 speed
    Shiftmate Compatibility | Jtek Engineering
    May 2014
    This is for my gravel cross bike build. I probably don't need a clutch derailleur but my understanding is that when they get really muddy clutch derailleurs don't suffer from chain suck like a non clutch derailleur will. I did find that Gevenalle does offer this derailleur though that is modded to handle the rigors and muddy conditions of cyclocross. BURD Rear Derailleur - Gevenalle
    I can't find any reviews on it to see how it shifts compared to other brands of derailleurs. Gevenalle shifters have gotten great reviews and I ordered a pair if their levers. I might give this derailleur a try.
  1. Short cage derailleur true capacity?
    By Alias530 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2017, 04:04 PM
  2. What is the difference between SRAM RD long cage/short cage pulleys?
    By gibsonlespaulspecial in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2015, 05:17 AM
  3. long cage or short cage deraileur for 1x10
    By ToneyRiver in forum All Mountain
    Last Post: 03-17-2014, 02:21 PM
  4. 1x10 set up worth replacing Shadow+ XT Medium Cage R Derailleur with ZEE Short Cage?
    By PCTele in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-02-2013, 03:18 PM
  5. Zee short cage shodaw plus or xt medium cage shadow plus?
    By GVSS in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-08-2013, 04:19 PM
