Shimano XT cranks: Boost v. Non Boost- Mtbr.com
Results 1 to 10 of 10
    Hi,
    I would like to run a 24-34 XT crank with an 11-42 cassette(11 speed) on a 27.5 bike to get the same low gear as a 26'er with XT triple: 22-34-Bash and 11-36 cassette(10 speed).
    The 27.5 bike has a boost rear. The XT boost double cranksets that are for sale come with a low of 36-26, so I want to buy the cranks separately and add the 24 and 34 chainrings. What is the difference between the boost XT crank only and the non boost XT crank only? For instance, these two:
    Non boost ($98): Shimano XT FC-M8000 Single Crankarms > Components > Drivetrain > Cranksets | Jenson USA
    Boost ($105): Shimano XT FC-M8000 Boost Crank Arms > Components > Drivetrain > Cranksets | Jenson USA
    Is the only difference a 1.6mm spacer that comes with the boost crank (50.4mm v 52mm chain line)? I assume I can add two chainrings to either crank. Is that right?
    Thanks.
    I'm curious about the difference as well.
    Anyone get this cleared up?
    RAKC Industries
    Jan 2017
    This was one of those things that the OP answered his own question. The difference is chainline, thats it. And 1.6mm worth of difference. Basically halving the extra 3mm if boost 148 rear. May help with chain ring clearance (maybe able to go one size larger) Can used standard crankset as well with no ill effects.
    Sent from my SM-G950U using Tapatalk
    Life on a bike doesn't begin till the sun goes down.
    I'm still not clear on how the chainline is achieved in this guise vs non-boost? Is the extra width then just from a few BB spacers? I looked at Shimanos tech page and it did not mention different part numbers for either boost/non boost arms so I'm hoping spacers are the key here.
    Sep 2016
    I believe the spider that holds the chainrings is further off centre I think boost model. It's not a spacer thing.
    Oct 2017
    Quote Originally Posted by Dexter-01 View Post
    That makes the most sense. That's how it is on road stuff (130 vs disc spacing).
    do not want to start another thread. getting first boost frame this weekend, a Tallboy. Is it okay to use a non-boost crankset?
    Reputation: Millennial29erGuy's Avatar
    Feb 2017
    In my experience, yes
    My name is George. Iím unemployed and I live with my parents.
    2017 BMC Speedfox 25-622 ISO
    2017 Salsa Timberjack 40-584 ISO
    I'm doing the XTR M960 1x cut/grind/polish mod with a 30t Oval snaggletooth so I no longer am worrying about the boost/non boost spacing.
  1. Non Boost cranks on Ripley LS with boost
    By marcus_dukakis in forum Ibis
    Last Post: 09-27-2017, 10:56 AM
  2. Niner RKT 9 with boost conversion and non-boost crank ?
    By philreske8614 in forum 29er Bikes
    Last Post: 08-30-2016, 10:57 PM
  3. Replies: 0
    Last Post: 04-26-2016, 04:03 AM
  4. I see Boost xt cranks... Is there xtr Boost cranks?
    By SB Trails in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-16-2016, 09:57 AM
  5. Boost or non-boost fork for 5010v2?
    By furball in forum Santa Cruz
    Last Post: 02-03-2016, 09:10 PM
Members who have read this thread: 37
