Shimano 10-speed rear derailleur with 9-speed cassette?- Mtbr.com
Results 1 to 10 of 10
    Feb 2015
    Hey MTBR,
    My plan is to gradually (eventually) change my drive train from 3x9 to 2x10.
    I am wondering if it is possible to use a 10-speed rear derailleur with a 9-speed set-up.
    Currently:
    - 2014 Kona Prcept DL
    - Shimano CS-HG80 9-speed 11-34T Cassette
    - Shimano XT HG-93 9-speed chain
    - Shimano SLX RD-M662 9-speed Derailleur w/ Shadow
    - Shimano SLX Front Derailleur (don't remember the model at the moment)
    - Shimano Deore 3-speed, 22-33-44T, Crankset
    Will using something like...say...Shimano XT RD-M786 work with the current set-up? I am not sure if there is a different ratio between 10-speed and 9-speed.
    Any insight would be greatly appreciated!
    Thanks,
    Victor
    2008 Kona Shred
    2014 Kona Precept DL
    Nov 2014
    I thought sure there was a sticky for 9/10 speed compatibility...but sure enough I checked and it's not there.
    I think you'll find this does not work.
    Best of luck on your setup.
    Jun 2014
    9 and 10 speed derailleurs are not compatible, however 10 and 11 speed are, now that the XT M8000 group has been announced, you will have more options for your upgrade. It also looks like there are some aftermarket cassettes coming out soon to add to the mix. A 2x10 speed drivetrain using an 11 speed derailleur will give you more options when you buy it and down the road.
    RAKC
    Reputation: tigris99's Avatar
    There is no difference in performance between slx and xt for the rd anyway, just slight weight difference. I own both and a Shimano zee currently fitted. Rds ALL SHIFT THE SAME bit slx vs xt shifter, that you notice.
    But 10 speed rd not compatible with 9s shifter. Other way around works (not the smoothest shifting, very slight margin to get shifting right).
    If you feel you need an upgrade then just go 10speed. Not sure how many deals are left but over the winter you could go full xt for like $175. Shifters, rd (fd doesn't matter) and cassette (kmc chains that I use are $27 a piece as of last check)
    Fat-tired Roadie
    Nov 2007
    The break in compatibility is why my older bike is staying some manner of 9-speed until I can't get the parts anymore. Judging by availability of stuff to keep a 2x6 drivetrain running, I think I'm good until at least 2045.
    You pretty much have to bite the bullet on the shifters, rear derailleur, cassette and chain all at once. I've heard conflicting things about front shifting.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by tigris99 View Post
    If that's your version of working I feel bad for your drive train.
    RAKC
    Worked fine for a year and a half. Shifted far better than anything I had previously owned. 9 speed slx rd and 10speed slx shifter. I say not smoothest because now I'm running xt shifter and zee rd and its smoother. But never access wear on chain, cassette or anything. And even my now xt/zee combo took a couple tries to get shifting perfect.
    Sounds unlikely - a 10 speed Shimano shifter pulls almost twice as much cable as a 9 speed shifter.
    Feb 2015
    Thanks for all the information from everyone! It looks like I'll have to do a full upgrade to switch to 2x10 (or 2x11).
    I'll definitely keep an eye out for any new and upcoming SLX / XT parts.
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    9 spd SRAM shifter and 10-spd Shimano rear derailleur, with 9 speed cassette works. Many have done it, including myself. The trick is a small spacer at the rear cable anchor point to tweak the ratio perfectly. (Works without it but not great). This only works since the 10-spd Shimano rear D has a ratio very close to a SRAM 9-spd rear D.
    Santa Cruz Tallboy 4
  1. Will an 8 speed rear derailleur work with a 9 speed shifter and cassette?
    By CyclesnIPAs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2017, 04:35 PM
  2. Rear Derailleur touching Cassette since replacing 8 speed with 9 speed
    By rebelscum in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-07-2015, 02:13 PM
  3. Will a Shimano 9 speed 12-36 cassette work with SRAM short cage rear derailleur?
    By Stonebreaker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-16-2014, 06:29 AM
  4. Sram TYPE 2 10-Speed Rear Derailleur with 9-Speed cassette + -speed Gripshift
    By jaxson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-02-2014, 09:43 AM
  5. 12-36 9 speed Shimano cassette with SRAM X9 rear derailleur?
    By Earthpig in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2013, 09:35 AM
Members who have read this thread: 16
